Hey guys parting out my 32 gtr
It has a few little mods done
Link g4 Ecu tuned for 330hp at 14psi
33 gtr brembos front with dba slotted rotors front and rear less the 1000ks old
33 gtr front seats in good condition
33 gtr wheels full set with little gutter rash with good 255's sumitomos
Nardi steering wheel on good condtion
Torque split controller
Motor has 120k on it and doesnt use oil
Gearbox shifts nice and tight
Also have race pace adjustable cam gears and r34 gtr dump pipes
Apexi pod filters
All parts are available from car
Already sold:
Bonnet, grill, front drivers, guard and front lip
Prices and photos of parts available at request
Best way to contact Loren 0403402904
Located sunshine coast qld
https://www.sau.com.au/forums/topic/439045-wrecking-r32-gtr-qld-sunshine-coast/
1000 ono for the front brembos with the 1000k old dba slotted rotors and 300ono for standard Gtr including the slotted rotors
I am negotiable On prices as im not too sure what everything is worth
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
