Hi Guys
So I'm taking my car to my mechanic for a freshen up and to ready the engine for some proper boost (skyline r33 RB25DET)
I want to sort out all oil leak issues - will obviously be doing the rocker cover gaskets,half moons etc...
What else should I replace while there? Anyone know what other common leaks the RB25DET has?
https://www.sau.com.au/forums/topic/439055-common-oil-leaks-in-an-rb25det/
Yep.
Common spot is the camshaft seals. You would be mental to pay someone to replace just those without also doing belt, tensioners, water pump.
An oil leak makes no difference to how much power an engine can make.
What is involved in this freshen up?
How will it stop it going bang?
Edited by superben
Yep.
Did my 100k service about 10k ago. Well the camcover gaskets are leaking pretty bad(as in all RB's) so its kinda obscuring what else could be leaking as well., hence be wanting to know what could be leaking :)
Freshen up will include,walbro gs342, new breather hoses, transmission cooler and fixing up of all oil leaks (4th March) and obviously usual 5000km service(oil and filter change)
Will be installing new radiator,stage 2 shift kit, new radiator hoses, highflow turbo and 550's on my trip after that and then ready to tune (5th May)
  • 3 weeks later...
you would be wise to check whether they actually replaced the cam seals or not. cam seals = front of motor, where the CAS bolts onto. mine leaked at 160k because they werent' changed at the 100k service.
cam cover seals are easy to do yourself. cam seals are a lot more work, timing belt off etc.
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
