R33 gtr vspec front seats drivers has small rip on bolster very tiny tho $700
R33 gtr brembo brakes front And rear freshly painted etc comes with brand new rotors all round still in box also comes with Bmc57 and booster $1800ono
R33 gtr rear seat $200
R33 gtr pull type gearbox $900
R33 gtr drivers side 2 peice side skirt $50
R33 gtr engine wiring loom $150
R33 gtr standard Ecu $70
R33 rb26 exedy clutch with brand new in the box clutch plate $250
R33 gtr air flow meters $100 pair or $50 for one
R33 gtr bov set up $130
R33 gtr window switch $60
R33 gtr front strut brace genuine $70
R33 gtr rear strut brace genuine $70
R33 gtr alternator reconditioned at some stage $100
R33 gtr tailshaft $100
Rb26 standard front pipe $50
R33 mint leather gearboot with matching handbrake boot carbon style $50
R33 gearbox surround with nismo shift pattern $50
R33 Gtr genuine wing $250
R33 Gtr boot interior $70
R33 Gtr genuine matts need a clean $40
R33 lock bar $30
R33 Gtr fuel pump $50
R33 Gtr vspec diff $300
R33 Gtr vspec shafts $180 pair
R33 Gtr washer bottle $40
R33 Gtr radiator $70
R33 Gtr clutch fan $40
R33 Gtr clutch master $70
R33 Gtr gearbox crossmember $50
R33 radio surround $50
Many other parts available
Gold Coast but happy to post
0487924497
post-50709-0-93879200-1392264190_thumb.jpgpost-50709-0-52742700-1392264220_thumb.jpgpost-50709-0-71571100-1392264285_thumb.jpgpost-50709-0-39141100-1392264307_thumb.jpgpost-50709-0-58793100-1392264336_thumb.jpgpost-50709-0-95245100-1392264399_thumb.jpgpost-50709-0-79002900-1392264428_thumb.jpgpost-50709-0-45963200-1392264459_thumb.jpgpost-50709-0-58664400-1392264499_thumb.jpgpost-50709-0-77315500-1392264781_thumb.jpgpost-50709-0-54751600-1392264833_thumb.jpgpost-50709-0-57674000-1392264861_thumb.jpgpost-50709-0-91282800-1392264933_thumb.jpgpost-50709-0-24975600-1392266155_thumb.jpgpost-50709-0-37409400-1392266164_thumb.jpgpost-50709-0-11184900-1392266172_thumb.jpgpost-50709-0-52030300-1392266180_thumb.jpgpost-50709-0-67731900-1392266417_thumb.jpg
Edited by toy515
https://www.sau.com.au/forums/topic/439063-r33-gtr-and-rb26-parts-galore/
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
