I doubt you will get much improvement if you change tyres alone. Most of the time I find its because people have way to much negative camber on the wheels, so your car is only gripping on a 20c piece of rubber instead of the full width.
Edited by sonicz
Even the khumo ku31 on my pulsar had zero wet traction with 50% tread
That's strange, I had camber worn KU31 all round in my GT-R, turned fine in the rain. About 50% on the outside. Nangkang are shithouse.
What is the one thing that connects your car to the road? Why would you skimp out on tyres?
That's a big call when you dont know what camber its running.
But yeah, if the car has been lowered its probably running too much neg camber, in which case some raising and/or extra adjustability will be required.
  • 4 weeks later...
hey guys, sorry to bring this thread up again but just an update. Took the old tyres off which had been worn bald in the inner edge due to running -2 camber up the front. Replaced them with continentals and problem solved! Just had to wait for a rainy day to test them. Thanks again for all the information guys
Edited by Eazyy
  • Like 1
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
