Not sure if this is the right section ....
I have a r33 gtst series2 track only car in my garage.
The garage is by no means a impenetrable fortress, i leave that special place for the GTR.
Can i insure a car just for theft? or something along those lines even tho its not registered and will never see the road?
Or can i put it onto my house cover or something?
Or are every ones track cars uninsured?
Just with all these thefts dont want the thing to get nicked !!
https://www.sau.com.au/forums/topic/439088-insurance-question/
Shannons do a laid up cover for just your purpose. Basically it covers insurance against fire, theft, damage etc while ever the car is not under its own power. This includes while it's being trailered to an event.
I have 2 race cars insured under this scheme for about $700 per annum total.
It doesn't matter how modified they are, and you basically set the value of the car.
My cars are only cheapies - one's insured for $12k and the other for $20k. Just checking the policy, I'm paying $343 for the cheaper car, and $384 for the dearer one. I can almost guarantee that insuring a single car for $32k would be a lot less than the price of my 2 insurances combined. I would guess you could insure a $50k race car for under the $730 combined I'm paying. Just having 2 policies means 2 lots of administrative fees etc.
Give them a call and get a quote - costs nothing and is easy.
    • *that* is a question for chatgpt (or someone that understands maths....but I'd try chatty). Drop them the table and ask for the formula
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
    • Here’s the updated and installed muse replica nismo ones … very happy with the outcome. Eventhough I painted my whole rear end due to my rich idle lol.
    • Hmm. I had a good look (w/o searching, because I'm not logging in) and couldn't see it either. I distinctly recall the thread, not many weeks ago. It must have been removed or perhaps put into the back section. If it was in Off Topic you should at least have been able to search it up. So if I'm not hallucinating, it is fairly decently removed.
