Ever heard it said before that our cars only deserve the best & that Car Washes should be neutral pH?
Detailers say that one should never use dishwashing detergent because of its pH right?
Well, I got to thinking about this > bought myself a pH meter thus,...
In Blue Mtns air, the meter reads 7.0
In Blue Mtns tap water, the meter reads 6.6
Throughout this thread so far, the Car Washes tested (in order) are...
* 5 Star Wash n Wax from The Reject Shop
* Polyglaze AutoWash Gel
* Meguiar's Gold Class
* Mothers California Gold
* FW1
* Meguiar's Ultimate Wash n Wax
You're welcome to read on and comment!
Are you surprised?
I mean, neutral pH for a Car Wash should be in the range between 6.0-8.0 right?
https://www.sau.com.au/forums/topic/439094-p-h-of-car-washes/
Good Q.
I washed the pH probe in a bucket of water in between each reading Anthony > wiped it down > went to the next Car Wash...
As I looked at the pH probe whilst in the water, it would continually read 6.6; so you'd be correct in thinking that any Car Wash which is in the proximity of 6.6 will stay about the same > any that has a pH of less than 5 for example will be diluted somewhat, and read closer to 6...
For example, Concentrated Hydrochloric Acid has a lower pH than Diluted Hydrochloric Acid (aka Muriatic Acid).
Good Q.
Interesting. seems some of them are a bit out. quite a bit acidic there. Great info thanks Terry! I might have to get my Meguairs Nxt Gen car wash tested!
It won't matter once mixed with water. Typical recommendations are one cupful per bucket so in the end you will end up with a tiny amount t of shampoo to water ratio. More important is lubricity of the product and it's ability to clean without stripping wax or sealant on the surface of the paint
Thanks for helping me back onto a learning curve again junkie, as I'd not heard of lubricity before.
I presume it's a mechanism whereby there becomes a reduction of "surface tension"?
In that case, dishwashing detergent would also have high lubricity qualities, but if so,...
* why is it recommended that you don't use ordinary dishwashing detergent?
* how does it strip wax and sealant, and yet car wash detergents do not?
* why do detailers and car care product sellers mostly refer to pH balance?
Thanks in advance for assisting me...
So how does the old Morning Fresh stack up Tez?
interesting that FW1 actually faired pretty well considering the bad wrap it gets...I still often use dishwashing liquid pre polishing only, it does the job and its cheap and plentiful...something like ct18 is better though..however on cars I have full detailed with sealants, waxes etc the dishwashing liquid never goes near them again....there is better products that add to what you have already put down and others that will strip it...
Oh Dear...
I was hoping no-one would ask me that!
My wife has umpteen detergents around here > but now you ask...
I shall grab one tomorrow!
FW1 has that disadvantage that grime and grit will abrade physically, the wax, the sealant and the clear.
I've found it useful for taking off exhaust residue (after washing the car); which reminds me lol...
For a major detail, I use dishwashing liquid for the first 'major' wash - before I commence the clay bar phase.
Dishwashing liquid does wonders to 'strip' existing wax and grime. I use AMMO foam (Ph neutral/balanced soap) for lube when I clay the car.
For a normal wash AMMO is fairly soft and won't really strip your protective layers, but I use 350gsm microfiber towels for the wash for picking up/removing grime etc (however, I will fold over the towel multiple times so I don't drag grit across the paint).
yeah, its basically what a decent quality car wash will do, provide a lubricated layer between your paint and whatever you wash your car with, helping to minimise swirling and "suspending" dirt particles
ph ratings mainly apply to strong chemicals like wheel cleaners, as some use acid based ingredients and others will use strong alkaline ingredients and you really need to know where to apply a certain product without harming the surface...
as far as dishwashing liquid goes, its basically a degreaser and wax is an "oily" coating on the surface. by that i mean, only the really expensive stuff will be made with a high content of real carnauba wax and everything else will have some kind of petroleum product in it, mixed with wax to make the stuff cheaper to produce and aid the application process. however, some new sealants will probably be a lot more resistant to dishwasher liquid
Edited by junkie
"Surfactant" process?
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
