i am what you would call a newbie.
and i was simply just wondering to convert my skyline to e85
what would i have to do ?
cheers, sorry if its the wrong place.
Are you after power, or just to convert to e85? There are plenty of off the shelf kits available to simply change the injector pulse duty for running ethanol in any vehicle, but it isn't like what most turbo guys run for maximum power. You really need a standalone ecu for that.
It is highly likely you wont do an emissions test, just a sound test and inspection.
Just quieten the exhaust up, enclose the pod filter (if you have one) and make sure nothing vents to atmosphere.
DECC inspection needs to have factory items fitted. They generally take pics of the car when pulled over, when it goes for the inspection, and the on a database with stock engine bays.
Back when I had my DECC test the inspection guy had a checklist to tick, a quick glimpse I could see
He even had to draw a diagram of the exhaust, drawing all mufflers, the cat and how the exhaust ran under the car.
Ive done 3 DECC inspections and passed with a custom 4 inch exhaust and an 800hp motor. Pics were taken on the rd and taken at the inspection, as long as you dont change "viewable" items between pictures taken its ok.
As long as all aspects are legal (noise, plumbed back) you will be fine.
Correct, high flow cats themselves are not a defect. To pass emissions you need a Euro 5 cat with 500+ cells and a really good tuner.
My 500 cell cat and my one cell cat are identical from the outside so even if they took a pic on the rd and at the inspection they would see the same thing.
As for noise my 4inch turbo back was 88db with some minor "modifications".
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
