hey guys
have recently dropped an RB26 into my gtst.
resistor pack is wired up as per roys tutorial, injector plugs have pulse but the ohms are all over the place and injectors wont fire when plugged in.
injectors are definitely good.
wiring has been checked 3 times.
new cas put in.
were absolutely stumped.
auto elec coming in on monday to wire up a direct feed for the fuel pump and have a look over the injector issue.
halp me pls
https://www.sau.com.au/forums/topic/439117-rb26dett-injectors-not-firing/
hey there man, i did a 2.6 conversion into my 32 gtst. i had a similar problem but i had no power to injectors at all. 6 pin plug that sat behind the passengers headlight had 6 male terminals in the plug(2 other pins beside them) . i hooked battery power to all 6 pins and car fired sweet as. (my car run without resistor packs however it is highly recommended to run them) ive done it and had car running fine with no resisitors. just make sure this plug i mentioned is plugged into a wiring harness this harness should run along the front of the vehicle and plug into the resistor pack which sits near the battery on gtr's for memory. if your not running a 2.6 engine loom or youv fitted aftermarket resistor pack you may be having troubles there.
Guest
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
