Hey all,
About two months ago, I had a bit if a miss around 4500 rpm, nothing major, just a bit of a flutter that would be gone after a second or so. It only did it about half a dozen times and then stopped.
Today, about 300 meters before I got to work, I felt like I had NO power, it was almost like the clutch was slipping... Ducked out at lunch time and it was even worse, couldn't rev over 2500 rpm under load (in neutral she revs fine). Thinking I got some crappy fuel, I went to repco and grabbed a bottle of Nulon total fuel system cleaner. Go back out to the car, but it wouldn't start!
I spent about 5 minutes cranking it over before it spluttered to life.
I nursed it home after work with the issue, it idled fine, ran ok up until 2500 revs but anything over that it was missing badly.
Went out about an hour ago to start it to see if I could see the coils arcing out, but it wont start again!
Am I in the right direction with the replacing the coils?
Also, not to try and start an OEM vs Splitfire vs whatever discussion, but for an OEM set of coils, what kind of money am I looking at?
Right now, Splitfires are around the $550-600 mark on ebay, but OEM's are going for about $300 for a set... But I've read everywhere that OEM's are super spendy compared to Splitfires..
EG - http://www.ebay.com.au/itm/Genuine-Nissan-Ignition-Coil-Packs-Skyline-R33-Series-2-RB25DET-R34-GTR-RB26DETT-/131004016395?pt=AU_Car_Parts_Accessories&fits=Plat_Gen%3AR33&hash=item1e8072a70b&_uhb=1
Car is stock power wise, just a Kakimoto N1 system.
Any help would be appreciated!!
Clean your air flow metre first would be my advice. You can get a can of the cleaner from autobarn. After you've ruled that out check the gap/condition of the spark plugs. Maybe then have a look at the coils if it's still no good. Best to rule out the cheap stuff first
  • Like 1
If you can't rev it past 2500 it sounds like its in limp home mode so starting at the afm is probably your best bet. Also as well as cleaning it pull the cover off and have a look at the soldering. It may be time for a resolder.
I'm with them. AFM first.
As to Splitfires vs OEM. OEM used to be more than Splitfire, which was why Splitfires used to be the only sensible choice. Then for a while they were about the same price.
What I would be worried about, particularly buying from eBay, is the fake OEM coils out there. There's a limit to how cheap thse things can get, and I suspect that the circa $300 sets are below that point.
Thanks for the starting points guys!
1)
Checked all the fuses - all are fine.
2)
Pulled the afm. It wasn't gunked up, just a bit of black crap on the mesh. Regardless, I pulled it all the way out and gave it a good squirt with a residueless contact cleaner. Still no start.
Just about to try and get the coil packs out and see if I can find some cracks and silicone them up...
It cranks over, but there doesn't seem like there is any combustion. Just the starter spinning the engine.
How do I check the fuel pressure??
I've never had to deal with fuel issues before.. only with two strokes!
I am getting the smell of fuel through the cylinders when a plug is out and it's cranking
Tried starting it with the AFM unplugged - no dice.
I've just pulled all the coli packs out...
Not getting ANY spark from the plugs resting on the side of the block from any of the coil packs!!
Good power is making it all the way through the loom when cranking to the plug for each coil - around 7.6v in each plug..
Check ALL Fuses and Relays. Even disconnect and reconnect the ECU.
I discovered I had a relay in the 31 playing up. Fuel pump would not always prime but once it did, the car would start and run fine.
Replaced the Relay and it's been perfect ever since.
I'd look more towards the fuel pump based on the info supplied.
It's rare to drop multiple coils in a short period of time.
If you fried the ignitor, it'd drop all coils at the same time.
Dying fuel pumps will usually give you a hesitation or flat spot then run fine for a bit before they actually stop. I'm not sure how/why, but many I have diagnosed have done this.
Remember; a dead fuel pump might flow fuel, but not enough pressure to drive or rev (or even start).
To test coils, get six mates to come over and let them hold a coil each as you crank it. If they all jump back and start swearing at you, your spark should be good. Check fuel system.
Testing the fuel pressure requires a gauge and some hose/fittings, which can be had for half the price of a new fuel pump.
Also check any fuel filters.
Goodluck!
Mark :)
Ok. I pulled the plug for the CAS gave it a clean with afm cleaner- now I'm getting good strong spark in each coil/plug.
Replaced all plugs.
Cleaned the afm again.
Pulled all fuses and gave them a squirt with contact cleaner. All fuses look good, the ones that looked a little iffy, I replaced. Still no start.
Replaced the vacuum line for the fpr.
Replaced the fuel filter (Z200).
With the new filter plugged in, I left the hose disconnected from the fpr and tried cranking it. Not a drop came out. Shouldn't it flow out?
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
