Looking to hire some shed/factory/workshop space in eastern suburbs of vic to do some work on my car. Will be temporary, preferably with a hoist. Car can be stored outside (but still in a locked up area) when I am not working on it. The closer to Croydon, the better. Let me know if you have the room. Ta
https://www.sau.com.au/forums/topic/439135-wtb-workshopshed-space-east-vic/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
