Hoping for some quick responses as I'm about to pull the pin on a 2004 Dec build series 2 GT350 sedan this week and have some final questions I have not been able to resolve by reading everything on this site (or maybe I missed it !)
1. Immobiliser
This car has no additional immobilser that I can see other than the factory standard. Others cars I have looked at have aftermarket immobilisers.
So does this mean this car has been properly complied ? Will this be an issue with comprehensive insurance ? I'm 43yo with life rating one so any recommendations in Vic I've called around the majors and looking at around $1100-1200
2. Tyres
Its still fitted with the Japanes tyres it came in with still (215/55r17). I'm looking at putting 225/50r17 on it (will keep the series 2 rims quiet happy with the look of them) but are there any reasons I should stick with the factory spec size ?
3. Cameras
This car has both rear and front side cameras fitted to the nav system. I have no idea what use the front side cameras are but my concern is they will be taking up an input/av slot in the nav/tv system so will this mean there are no further input slots for an aux input for an ipod or hard drive mp3 player ?
4. Pedals
Series 1 had the slotted sports accelerator/brake pedals which I liked - is it possible to fit these to the series 2 ?
https://www.sau.com.au/forums/topic/439170-urgent-350gt-questions/
1. Crap compliance. Some people tend to get around it with a clause tying the vehicles system to a murano which its not.
It should have been done.
2. That's not legal. They NEED to be done.
3. No. That has a dedicated input.
4. Unsure.
The front cameras are called T-junction camera. Factory option. Its when you pull upto a T-intersection but your view of oncoming traffic is obstructed by cars/buildings, you just poke your nose out and it will come up as a split view on the nav screen.
Thats what they do. BMW made i big thing out of it on their current shape 7 series having this feature. Pretty clever.
Tks Howaitonaito I can sort of see the logic but I think I'd be more likely to edge out eyes up and then gun it when I see a break than try and look at the screen....will try it and let you know....
1. RACV website gives an online quote with check boxes to indicate the alarm/immob options and there is a setting for nothing other than factory standard so this is what I will be using. With $1k excess it comes down to around $990 for me which is less than what I thought I'd pay
2. Have sourced some top end 225/50R17s shouldn't throw the speedo/odom out too much
3. Good to hear, do those FM exapanders on ebay from NZ work ? Easy to install ?
4. Pedals, its cosmetic only of course, some on ebay for about $120 from the US will order some and hope they fit ok
I ran 235/45/17 once. when i do 100kph its actually 105-107 on my speedo. now on my 19's 245/35 I do that on 110kph lol. the benefit is that when i hit a speed camera if i sit around or just over the speed limit i still know im under.
well with the 235/45/17 already its already out by a few lol.
Comparing 215/55R17 to 225/50R17 the difference is sfa - rolling circumference is 2038mm to 2003mm so less than 2kmh indicated difference.
245/35R19 is 1995mm would throw it out by a fair margin ;)
Well after driving around in the Skyline for two days I'm pretty happy - it drives n i c e
I'm certain the 76k kms are genuine as the filter sticker in the glovebox in indicates it was 46k at changeover and there are some japanese stickers in the doorwell that to me appear to be some kind of export confirmation stickers and they indicate 63k kms. I know the people I bought it off had it just over a year and used it as the wife's get-the-kids-to-school car (really) so all those things lead me to believe the odometer.
Stereo works but the cd skips on some cds and doesnt read some burnt cds so I'm looking at running a cable from the tuner in the boot to the centre console and have an old samsung galaxy tab which fits perfectly in the center storage box so I'm thinking I'll dump all my cds into that as a music player and can still use the sat nav it has which uses the gps....
Will this give me the pin code in case I ever need new keys ?
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
