Skyline People,
I have managed to get my hands on 2 complete RB20 ECCS manifolds and am trying to work out the best way to go in building an intake with twin throttle bodies. I need to move the throttle body to the front of the plenum to reduce heatsoak on my intercooler plumbing so.....
Which would be the better option in your opinion:
- Running two throttle bodies side by side on the front of the plenum may have to customise it a bit
- Running basically two intakes, one throttle body has runners that feed cyls 1,3,5 and the other feeds 2,4,6
- Running basically two intakes, one throttle body has runners that feed cyls 1,2,3 and the other feeds 4,5,6
Just trying to work out what would be more efficient. Would there be any dramas with additional injectors? Would I get equal air flow if I just put a fork in the intercooler plumbing before the throttle bodies?
Thanks
https://www.sau.com.au/forums/topic/4392-twin-throttle-bodies-on-rb20/
Gradenko,
Yeah that's what I want to do. Pretty much the same as the pictures you posted but facing toward the front so I can shorten the intercooler plumbing. Will probably have to mount the throttle bodies one on top of the other so that I can fit them.
Who owns the car in the background? Any other details on it? Who did the work on the manifold?
Thanks
I don't know whose workshop it is or who owns the R30 in the background.
Are you sure mounting the tb's on front will clear accesories around it? Is there enuf space on the forward face to fit 2 tb's one above the other?
I'm hesitant to modify the factory plenum to feed from the front because its been designed to disperse air coming from the passenger side. We don't really know how much air is going to each cyliner after the factory plenum has been hacked, cylinder 5 & 6 may end up running lean in low pressure conditions. Maybe a flow test is before and after is needed just to be sure.
That's why I was thinking about running two intakes. 1 throttle body will feed cylinders 1,3,5 and the other will feed 2,4,6. If I just cut the crap out of both manifolds and have it set up like a 2JZ supra engine I think it will work OK.
I'm pretty sure I have enough room. The other option is to get somewhere like Nizpro to custom make a plenum for me.
Does the 2JZ intake look anything like the 1JZs? Feeding alternating cylinders sounds like a lot of work.
Nizpro will rip you a new one if you ask them for a plenum chamber. Have you read this thread? http://forums.skylinesaustralia.com/showth...s=&threadid=553 Theres a link in it to a guy who makes RB plenum chambers for a decent price.
    • And half of them have been converted to turbos.
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
