SAU.NSW will be holding a Tech Night this year about Engineering Cert, Clearing Defects & How to Negotiate with HWP (if that's possible)
Good work Terry! Will be attending that one for sure ;)
That tech night will be awesome - I'll keep an eye out for it
Yeah certainly one that should be of interest to ALL the SAU community considering our cars are targeted....
I have been out of the scene for a bit so will be good to get out and meet some more of the SAU NSW guys!
Would be funny if after the tech night, a couple of HWP rock up and defect a bunch of Skylines :P
Actually, it wouldn't be funny.
  • Like 1
Who are you are you new?? ?
In for engineering might go talk to him this week regarding my car
Lol always a newb!
Yeah something i might look into as well! I kind of avoided it as i figured they can defect you with or without it, but in saying that its pointless to go so far and not at least try get it through haha
Lol always a newb!
Exactly my thinking
Can I put my name down for this now lol
and will there be a limit on this one?
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
    • House of Fatz dry dock needs a clean sadly one of the long time stables is leaving this weekend   see ya mr purple
    • Hence why I've only modified my car into a pure daily. Everything has to remain reliable & roadworthy, while providing value and grin factor. It also must not be handcrafted to the extent that the car will be immovable if something breaks because you cannot get or make a replacement to at least limp around with.
