Garrrhhhhhggggg, does anyone know anyone selling a R34 GTT cat? Surely you must know Mat :-D, or whats the next best aftermarket cat to get? not so much for flow but for emissions, thanks.
If its for emissions you really need those Euro cats or stock ones... Aftermarket generally flow higher and may not get you passed the test!
In saying that, i sold my last one to BenRThirty4 on here...
Yayy, I have finally found a stock cat haha lol, gonna put it on tomorrow and change my plugs again, I must have damaged one of the plugs while gaping them because I've got a ugly missfire on idle and once I boot it it's fine.
Rightio heres another update.
I really hate myself right now.
Had a emissions test today after installing a stock cat, changing the plugs etc, farken failed and just, you wanna know why? Farking Crap Shell V-Power fuel and octane booster, even the testing dude told me that quite a few people have just failed using shell fuel, after changing to BP as he recommends it passes, now I gotta wait till Wednesday to get it re tested as they only do emissions testing on Wednesdays.
I can't drive my car from Friday so whippie no car again till that crap is sorted and my engineer signs off the papers, theres my rant lol, thanks.
Hey guys
Well from what I have read and from my understanding, especially now that Shell have once again changed their V-Power is that Shell just add way to many additives, and it's these additives that help you fail the emissions test because first of all the "cleaning" additives make the combustion burn hotter - first of all yeah this is kind of a good thing in a way as if the fuel wants more heat to combust it will help with detonation but by it running hotter it also causes you're car to lean out and also produce more NOx which is one of the things they test at emissions testing.
Secondly due to all their additives (cleaners, detergents, alcohols, colouring) you're seals don't like it, for example I've read on many places that peoples valve stem seals have started drying up and many link it back to the fuel - don't hold me to this one as you cant really pinpoint this although I kind of get how it could.
Again with all of Shells additive's it forms a film over you're plugs hence causing slight misfiring and also sticky seals.
Another down side is that their fuel is no longer as pure as it's stuffed with heaps of their additives etc and on another note of this, fuel consumption is increased (I've noticed much better fuel consumption with BP and alike.
I have been using and recommending Shell V-Power ever since I got into the car scene which has been around about 10 or so years, but lately they have really let me down.
I'm in no way or form trying to boost sales or kill sales from any company, just putting up my thoughts, research and experience.
Not sure how fuel could affect seals given that fuel goes nowhere near them.....
I run V-power and Caltex 98
Cant pick the difference, Plugs come out nicely etc
Id say its more the 20 year old cat, plus octane booster shit was your issue, not the fuel
Define this please.
I'm considering switching to Caltex (The wollies servo is closer than 7Eleven, plus the prices are cheaper. I find the 15c hike overnight ridiculous and don't but from the 7 Eleven until prices come down on par with the Woolies and Costco servos). Plus there's a bunch of 'save 4c/L' dockets at home :P.
Don't trust Caltex though.
Not saying that it was the sole problem for me, I said that it contributed to my last test with the octane booster, well thinking about it it would kind of impact the valve stem seals because when the valves open the gasses go through there hence to "POSSIBLY" contributing to early failure of valve stem seals.
Define this please.
I've only ever heard good from Caltex, my preference now is BP then Caltex.
I've stuck with BP Ultimate for a long time - used to run V-power but found car felt smoother and more km/tank out of BP. Could be placebo, though.
Take that with a grain of salt though, car has done < 1000km in the last 12 months (though I changed fuels ~ 4 years ago)
Back when my R31 was running good, I got an extra 50km from 55L fill up switching from Shell 91 to Mobil 91. All highway driving, same condition and driving style (I drove to Sydney to Kiama and back, two days back to back).
I put Caltex E10 (the only one they had) in the R31, it would stall on cold starts and ran a tad rough. Didn't do any testing with that fuel as I went straight back to Mobil for many years of happy motoring.
Used BP 98 a few times, ran the same as Mobil, but they generally are more expensive so no point using BP.
I've stuck with BP Ultimate for a long time - used to run V-power but found car felt smoother and more km/tank out of BP. Could be placebo, though.Take that with a grain of salt though, car has done < 1000km in the last 12 months (though I changed fuels ~ 4 years ago)
Chemist says,"Placebo effect is good!" :P
Funny how Ash is somewhat affiliated with Shell.
Umm no Tats is affiliated with Shell, pretty sure Ash is on his own :teehee:
BTW the new Shell ad says:
Can anyone tell me how a fuel could possibly add zip or vroom? Or is it just false advertising.
again with the placebos :P
also i posted this elsewhere - jen spotted you at ikea
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
