Hi everyone
,just wanting to know some good exhaust systems that I'm looking to put on my r32 gtr,
I've done a bit of research but just wanting second opinions n feedback to get me on the right track.
I'm wanting to put a turbo back system on it don't really have a budget just want a quality system to boost it up a bit and get that raw gtr sound. The Hks hi power system is catching my eye ATM, if anyone's got the same set up I'll be interested to know the details.
Thanks guys.
https://www.sau.com.au/forums/topic/439214-exhaust-systems/
  • Replies 47
Posted Images
Change the front pipes to equal length ones.
Do this!
I dont own a car with a 26, but I do know that equal length front pipes make them sound like porn (I hate the standard 26 note, too me they sound like n/a RB lol)
Oh not to mention I am sure there is a decent performance increase over standard front / dump pipes!
(equal)
(unequal)
Same system besides front pipes
Edited by Bennis
https://www.sau.com.au/forums/topic/439214-exhaust-systems/#findComment-7205232
I got quoted 2500 for a stainless system from the front pipes back. Hi flow cats, main pipes split into 2 2inch pipes back down into a 3inch to the tip.
Fergot what the place was called but he said that a gtr with stock turbos theres no point changing the outlet pipes and front pipe as there will be not much difference from stock...?
Not a fan of the cannon tips either need something that flows with the car.
Whats use reken of the mine's silence vx
Heres the link :
http://www.mines-wave.com/E_09/CATALOG/SKYLINE_E.html
https://www.sau.com.au/forums/topic/439214-exhaust-systems/#findComment-7206179
Heres the link :
Horse shit, in a R32 GTR the dump pipe - front pipe and cat is the biggest gain even on stock turbs, it really wakens the car up
Build your exhaust for any future possible mods, there is no such thing as to big when it comes to an exhaust, just what you can fit and how loud you can handle it
My recommendation is dump pipes with 3" outlets, twin 3" front pipes with 3.5 outlet and full 3.5 exhaust unless you plan on going 3ltr then go 4" instead of 3.5
https://www.sau.com.au/forums/topic/439214-exhaust-systems/#findComment-7206449
Yeah when he was telling me this I was like yeah whatever .
Alright deffo going a turbo back system. Now just need to figure out if I want bolt on or custom
That system you just recommended . How much would something like that be worth, just a estimate.
https://www.sau.com.au/forums/topic/439214-exhaust-systems/#findComment-7206951
Depends on meterial used, I use these guys as its not worth custom on dump pipes and these spent the time designing and testing to make sue they work, I have both normal replacement style and the competition series, pay the money and get the comp ones, I recommend the black ceramic coated, bottom right
http://www.cesracing.com.au/products_2.htm
Then a good cat $250-$300 and catback $750-2000, again depending on meterial, mild steel coated is what I use as it is quieter an stainless
I got a custom system from Windsor exhaust custom made from the dump pipes consisting of twin 3" to twin 3" cats with 5" bodies then twin 3" trough to a single 4" center muffler then 4" out to a custom HKS 4" connon I made and the cost $1250 fitted
https://www.sau.com.au/forums/topic/439214-exhaust-systems/#findComment-7207105
2nded for windsor exhaust.
4" turbo back in mild steel.
5" cat.
2 mufflers.
weld pipe to manifold for wastegate.
wrapped the dump/wastegate pipe.
and made a turbo to guard (intercooler) pipe.
$1700.
I love the work.
its pretty quiet (how I wanted).
would highly recommend.
https://www.sau.com.au/forums/topic/439214-exhaust-systems/#findComment-7207179
Nice both them set ups sound good ,I like the more aggressive note sharper tone instead of the muffled tone.but titaniums ways to much for an exhaust.
How much kW or HP can you get from a good system like those ones yous described
On that link you sent it says 40kw gaiin just for them black ceramic outlets . Is that legit ??
https://www.sau.com.au/forums/topic/439214-exhaust-systems/#findComment-7208117
On a healthy stock 32, yeah pretty much, but not so much on 33-34s, those figures are from dyno testing done when designing those systems
As for gains depends on how bad the system you have is, if full stock with 20+ years of crap build up you could pick up a fair bit, but the biggest gains are dump-front-cat, then the rest depends on power level, the more power the bigger it needs to be
I designed my system to support 500awkws+ so overkill for most
https://www.sau.com.au/forums/topic/439214-exhaust-systems/#findComment-7208196
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
