Hey guys, I can finally and very happily say I'm a stagea owner!
Just recently picked up a 1999 Bayside Blue RSfour w/leather in beautiful condition for $11k. 100,000km. I might post pictures when i get around to it.
Just had a couple of questions:
1. I've noticed i get a little bit of belt noise when idling, not sure how to describe the sound, it's like a slight rattle/whistle i guess? And also, I noticed this morning as I turned the stag on I got a loud squeal from the belt which lasted no longer than 2 seconds then dissapeared, it happened each time i started until i went for a little drive then it was gone. Also happened tonight so I assume its a temperature/cold belt thing - no worries during the middle of the day. I assume the two are linked? I'd love to get it sorted asap, have searched the forums but not found a solid answer.
2. Just out of interest is there a way to make the dash brighter? Not sure if i'm blind and missing a dial for it or they're just slightly duller than what I'm used to.
3. Once again just out of interest: So i'm obviously using 98 octane petrol(despite my bank accounts better interests :P). Is there a difference in the petrol from different servo's e.g Shell vs BP? Do you guys stick to the same or?
Cheers Guys, other than the little bit of belt noise i'm getting I'm absolutely loving my new purchase!!
https://www.sau.com.au/forums/topic/439218-questions-about-my-new-stagea/
Hi let's see some pics!
Squealing belts are normally just loose or possibly worn.
There are a number of people supplying replacements for the dash lights in a number of colours as well as white. The brightness is not otherwise adjustable.
Cheers for that, I reckon I'll drop by my mechanic and see what he has to say.
Cool so I'm not blind ;) they're perfectly visible at night, I just turned them on during the day and wasn't sure if they were actually on.
Oh another question:
4. This is my first car with turbo, I don't plan on constantly thrashing the thing but out of interest, how long do you guys usually go/warmup before giving some more gas - I've been at least making sure oil temp >75c.
Also turbo timers, yay or nay? I've got one just not sure whether to use it or not.
Haha cheers again people!
White LED's wide spead (they have 5 little wedge LED's on the one bulb - search ebay, you'll see what I mean) for the dash. There is an orange filter, so if you want to put blue ones in, you'll have to disassemble the cluster to remove the filters.
Start engine, led idle for 30 sec or so, then light load till temp starts to come, then light boost till at normal operating temp.
Turbo timers? NAY! BIN IT!!!
If you install one, your giving a thief the three wires needed to start your car!
Just cruise before you get where you need to be, & if need be, just idle it for 15 or so seconds.
Has it had the 100k service - new belts, water pump etc? If not, book it in with Boostworx asap ;)
Don't hit boost until temperature gauge climbs off from cold. Just drive easy until temperature gauge is steady, ie first 5mins.
I've generally found Mobil 98 lasts a few kms longer than BP, dunno why, besides having Mobil in the tank every time I've had it dynotuned.
Going to do a tankfull of Shell vpower for my tune next Monday.... Will eventually report back to say if kms per litre is any different to Mobil. I rarely use Caltex 98. If I use United 100 I find the kms per litre is drastically reduced :/ ie 270km compared to 370km with Mobil. In stock form used to get 420kms, so it hasn't lost much when compared to power output being more than doubled.
Congrats on your purchase.
And I say no to turbo timer. Mine came with one, binned it.
(I've got blue dash led lights but never installed them...)
Thanks for that info guys, I've got a receipt from some work he got done 6000ks ago at Boostin OZ, not sure if this would qualify as 100k service. Here's what was done:
Complete timing belt kit and water pump, External Belts x3, cam and creak seals, water pump, pulleys and tensioner, external belts. On top of normal checkup service.
I'm assuming the squeal is a tension issue? after starting my car today while its been sitting around in about 25°C i still i got a nice 2sec squeal.
Also here's some pics of my new Pride and Joy:
I'll swing past my local mechanic tomorrow and see what he says. Definitely want to get it sorted because i'm getting the whirring/whistle belt noise whenever idling. Doesn't sound mean at all ha!
Very purty mate, congrats.
and about fuel, There is'nt one fuel that better, seems some people get better on one vs another. I use BP ultimate as it seems to work best for my car, but atm using v power as theres a shortage. Best bet is to try them all and see for your self.
As silly as it sounds; an overtightened belt can slip too, the whirring may be an indicator.
Have a poke at the belts when the engine is cool; you might notice that one is vastly different to the others.
Looks great in Bayside Blue.
Hahaha cheers guys, yeah the color/paint made me fall in love instantly when I saw it!
Mechanic is checking belts tomorrow morning so we shall see.
This thing is amazing to drive! Only thing i miss from my Magna is Cruise control! haha
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
