K guys....I'll try to make it as short as possible so here goes...
Car was in accident and after being down for a while decided to give it a go, so turned the engine(rb26) via the crank bolt and everything seemed fine. Tried to start and it constantly fouled plugs.Killed the fuel pump and barely got it goin(didnt really start) and heard tapping in the head so checked cam timing and both intake and exh cams skipped four teeth.
Set back timing as normal and did compression test. 1,2,5,6= 150-160psi, 3= 0psi, 4= 30psi.
So all intake valves kissed the pistons
Valves looked normal tho
Number 4
Number 3
Piston after cleaning the carbon off
The pistons dont look bad at all. From what i see it basically just smoothed out the rough finish on the piston top from the hit, but nothing I think a little rub with a piece of emery wouldnt fix.
Soooo....Im thinking the loss of compression is due to bent intake valves on number 3 and 4 even tho all of them look the same as the other cylinders???
My question is.....Can I get away with changing just the intake valves without touching anything else?
If so,I think I would change out all even though 1,2,5,6 read good compression.... and this leads me to another question.....How come only 3 and 4 lost compression? Shouldnt all the intake valves hit the piston to the same degree and cause the same damage across the board? as I did crank the engine like 20 times trying to get it to start!
What do you guys think
Edited by Don Dada
that is a weird result... before you pull the valves out I'd be doing the kerosene trick where you let it leak overnight to see which valves are actually sealing properly.
Also what kind of accident was it that caused the timing belt to jump 4 teeth on the crank pulley? sounds a bit strange
Was comp definitely good before the crash? May have busted ring lands or something that is hard to see.
Make sure the valves aren't sticking in the head and just being pushed closed by the pistons. It only takes a tiny nudge to bend valves which can cause them to lock in the guides. With the head resting on timber so you don't further damage the valves, turn the cams around and see if the valves close of their own accord when the bucket comes off the lobe.
Yea...Engine was perfectly healthy before. When I look off the head I was able to spin the intake cam by hand and watch the valves open and close. It was a little hard to turn in some spots but I guess thats normal depending on the position of the lobes against the buckets.
Will see if I get some time to do the kerosene test for now and I guess that would confirm leaky valves on 3&4....and if so then removal and inspection of the guides
More like replacing valve guides, stem seals, new valves most likely unless their run out is not bad, then seats will need to be cut.
However if you pull the valves out and spin them in a lathe or drill press or even a hand drill and if somehow they aren't bent, you might get away with just a heavy lap in to make sure they are sealing and then all good.
Well got some time to scrap out the intake cam and manifold and pour kerosene in the ports and well it instantly emptied out no. 3&4 and it also leaked out all of the other cylinders but at varying rates, some just barely seeped through.
Is it supposed to seal 100% so that absolutely no kerosene should pass through? Remember 1,2,5,6 read basically perfect compression.
Valve seal should be 100% when a head is brand new or reconditioned. In your case if they leak a little that's probably not too bad. If its leaking a lot then recondition time it is.
Hopefully 3 and 4 might need abit of machine work, but the others might just need a lap in with some fine paste and they will seal back up.
If you have the steel valve guides, take a close look at the tips entering the ports in case they are cracked after you remove the valves.
Looks not so bad on the piston front, id say 4 new intake valves, a bit of a lapping in and it may be good to go.
While your in that state, i may be wiser to just replace the 4 intake valves and get all the seats recut, valves resurfaced and lapped to ensure max compression.
Your there now, its not mega $.....
    • I'll tell her I put in a new air filter on it, which, it would have anyway with the ITB's In the end she isn't to fussed, she spends lots of money on hair, nails, make-up and all the other "required" beauty products that women use, plus I grease the wheels with shiny gifts and holidays wherever and whenever I can She once questioned my car spending "budget", but after itemising everything she spends on herself, and what I spend on her, and the fact that I don't care if she does or doesn't wear make-up and fancy pants perfume, or requires new outfits for every wedding, funeral or anything else she deems worthy, and I'm quite happy to go "real" camping, instead of staying in hotels or jaunts on cruise ships, she decided not to press the subject on how I spend funds, and has never asked "how much did that cost" again, so a win to me And how often can you say you really get a win with the fairer sex? She is a good woman, and in the big picture, I'm really lucky.....that she hasn't killed me yet
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
    • No. Go a different colour, and just trim it at an edge line. Even manufacturers do different panels different colours etc.
    • I see no real downsides to ITB's, apart from the initial cost of my drive in drive out lifestyle, the "upsides" is they sound cool and would add lots of smiles I am willing to pay to play for the extra smiles I've spent the morning googling and youtubing the BBR ITB's, a "little" extra power and throttle response, but alot more dort, and really, I'm only really in it for the dort Who knows, after all this money is spent I might even make 150kwatw....LOL
