I have up for sale my beloved R32. I am having to sell due to moving overseas for work, if I could take it with me I would :(
Here are the details:
1989 R32 Skyline GTS-t
Body: 165,xxx kms
Engine: 100,xxx kms - Previous owner put in a 95,xxx km motor before I bought, unfortunately there isn't any recipets, but I do have an engineering cert that says that it is not the original motor and has been replaced with a same model motor.
Manual
Engine:
  • RB20Det
  • FMIC
  • Upgraded Internal Wastegate - now makes 12psi
  • 3inch Turbo back exhaust
  • Apexi pod with custom airbox
  • Nismo Thermostat
  • Brake Cylinder Stopper
  • Included but not fitted, R32 gtst radiator air guide plate
Suspension/Brakes:
  • Nismo Front strut brace
  • HSD Coilovers
  • Rear calipers rebuilt, High temp Red paint
  • Front Calipers stock
  • Included but not fitted, R33 gtst front calipers rebuilt, high temp Red paint
Exterior:
  • Metallic Black paint, less then 1 year old
  • Extremely straight body, NO DENTS
  • 18inch white Work Emotion XT7s 7.5" wide fronts, 8.5" wide rear - NO GUTTER RASH
  • Rust Proofed
  • GTR front bumper
  • Deleted rear spoiler
  • Clear front indicators
Interior:
  • Greddy boost gauge
  • Nismo R32 gtst 320km/h speedo
  • Stock interior but in very good condition
  • Dash has no cracks! There is one small slight bubble
  • Leather handbrake boot with 'GTS-t' embroided on it
  • JVC 6x9s in rear JVC Splits in the front
  • Included but not fitted, Leather gearstick boot with 'GTS-t' embroided on it
  • Included but not fitted, Shadow Temp, Oil Temp, Oil Pressure gauges with sensors
She is currently registered till the 14th December 2014
ALL mods have been engineered and are legal! Will supply engineering certificate with sale!
Bad Point:
  • There is a noisy bearing in the gearbox - I bought it like this, been driving it as a dailiy for the time I have had it and it has been fine, hasn't gotten worse
  • There is no Stereo - does have the cables for an amp installed
  • Stereo surround has 2 cracks
Asking price:
$9,000.00 - NEGOTIABLE!!
If you have any questions, or to make an offer, please PM me, or text message or call: PH: 0402560758. Ask for Josh.
Edited by Saroon
https://www.sau.com.au/forums/topic/439253-fs-1989-r32-gts-t-forster-nsw/
    • I'm at the point of seriously starting a project to build and Arduino/mc (of some sort) based multigauge to go in the console where triple gauges normally sit. I have found a screen of the right dimensions. I would need to 3D print a bezel/housing to make it mount up pretty. That's doable. I would need to come up with interfacing circuitry for the EGT thermocouple. I'm sure there will be examples of that into Arduino out there somewhere. Ditto with characterising the output of the existing boost gauge's MAP sensor and the oil T gauge's thermistor. And then, because it is a screen, it can be controllable, so it can show more than the 3 gauges I currently have. So I can come up with a list of other things I want to be able to show on it that can be reasonably easily handled via an Arduino's inputs. I do not need this project. But the stepper gauges I'm using are giving me grief. It's time to come kicking and screaming into the 21st century.
    • Would you really prefer pillar gauges over something like this? https://www.haltech.com/product/ht-067010-haltech-ic-7-digital-dash-kit/ Or if you can spend more, this? https://www.haltech.com/product/ht-068000-haltech-uc-10/ I could write a thesis about how much better a modern dash is compared to a series of gauges.
    • People think it's a waste of space, ugly, etc, generally associate "emissions control equipment" with "bad". These OBD1 vacuum-only systems I'm not a huge fan because I think they don't go far enough. They're wasting some of the fuel captured because they start purging as soon as the engine pulls vacuum. Later OBD1/OBD2 they put an electric purge valve on them to vent only when closed loop is active so the ECU will trim some fuel out. Even later OBD2 with zero evaporative loss the tank is 100% sealed from atmosphere until you run the engine or press the refuel door release. The tank has to take much higher vacuum/pressure spec but you never deal with saturating the charcoal canister and losing some fuel that way. The fuel also lasts as long as it would in a 100% airtight container which is nice when you're dealing with modern E10 pump gas.
    • If your luck is anything like mine, what happens is in the process of pulling hoses to get access to the one leak you create many more leaks because every o-ring was on the verge of failing and the strain of pulling it apart caused it to fail. Sometimes life is simple, sometimes you pay twice trying to save once. For the R33 you can still get most AC components from Nissan, I use nissan epc data or amayama to look up the part numbers and then search for the cheapest/most practical way of sourcing from there.
    • The dirty secret is there is nothing recyclable about the plastic bag or old plastic bottles either. Our local trash collection explicitly calls it out as hazmat in both cases. Oil-soaked rags + paper towels too. Oil-soaked cardboard is also not recyclable. The most common case of oil-soaked paper like that is pizza boxes, which are explicitly compost-only from the oil. To my knowledge hazmat oil contaminated plastic the only solution is either landfill or "thermal recycling". Most plastics in my experience there is slow permeation of the oil it's holding into the container so it's very challenging to get it 100% clean.
