Hi, new to the site and new to the import world.
I've had my r33 gtst for about 4 good months now, have had no problems with it at all until now.
So the story goes i was casually driving along and I noticed the hicas light flickering on and off and losing power steering also, i continued driving as I wasn't far from getting where I needed to go. As I started accelerating again it wouldn't respond sounded as if it was over fueled/ flooded. I basically pulled over turned it off left it for about halve an hour, went back battery was dead.
Soo. The next day I replaced the battery as I noticed the battery I had in was pretty old. Drove fine for the past two day until this afternoon where it seems to be doing the same thing again? I don't know much about these cars and am wondering if anyone else has experience the same problem and can point me in the right direction of diagnosing the problem?
Thanks heaps
https://www.sau.com.au/forums/topic/439262-help-please/
HICAS problems shouldnt affect the engine/engine ECU so perhaps you have a bigger problem?
Have you done anything at all to the car recently? did tthe battery cable look O.K? If its a standard ECU can you get any fault codes out of it?
Sounds like more than one issue here, and I would look at whatever is causing the engine issue first as if its something electrical it may be shared with the HICAS ECU and fixing it will fix both problems
https://www.sau.com.au/forums/topic/439262-help-please/#findComment-7202247
It's currently completely stock. Other than the battery I haven't touched a thing on it.
The battery cables looked fine no visual signs of a bad connection.
I just went to put it back in the driveway and it took longer to crank as if the battery is dead again. Would you think if the battery is low on power again it could affect the ecu's functions
https://www.sau.com.au/forums/topic/439262-help-please/#findComment-7202260
Altenator? Yeah that'll do it, R terminal wire dodgy means the altenator would not have been charging properly or at all
figured it must have been a general electrical issue for 2 systems to be playing up like that
Easy fix, good to hear :)
https://www.sau.com.au/forums/topic/439262-help-please/#findComment-7202568
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
