Hi Guys,
I was told this is either a genuine Navan Nissan C34 or M35 Stagea pack rack accessory.
It has a nissan sticker and part number listed but I have not looked into it much, Google did not produce much for me :)
Made of full aluminium with collapsible ends its a pretty cool thing.
I had it on my C34 stag for camping trips, but with a little one on the way I do not think we will be doing much camping for quite a while.
Looking for $250
See attached pics for more info :)
Pickup from Adelaide hills or may be able to drop of around city area.
Roof racks are not included I am still keeping those at this stage(a) :)
Cheers
Steve
https://www.sau.com.au/forums/topic/439266-rare-stagea-pack-rack/
  • 1 month later...
Still available - open to offers
I would swap this for parts
Looking for stock RS4s Rims and stock suspension or anything else that may be of interest - chuck me a PM...
Also could get it to Melbourne over Easter probably for pickup from Fitzroy
Also have a stock cat back system for sale for 100 bucks :)
Edited by Cadavre
  • 1 month later...
  • 4 weeks later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
