Hi guys,
I've got two wastegates for sale, genuine TIAL 44mm MVR in the box unopened. Pick up and post is available. Details below -
Ultra compact design fits in very tight spaces, the unit stands only 4.17" tall, more compact than any other 44+mm external wastegate on the market today. These are leak tested after installation from the factory and can be removed if not utilized. 100% made in USA.
  • High temp NiCrFe based alloy is used for valve and 347SS valve housing will offer longer product life compared to competing designs.
  • High temperature silicone Nomex reinforced actuator diaphragm.
  • 17-7 PH Stainless Steel actuator spring gives consistent pressure at high temperature, resist "relaxing" at temperature to 900F (483C).
  • Nitronic 60 Stainless Steel is used for the valve seat, and valve bushing.
  • All Stainless Steel hardware.
  • Mating weld flanges are 304L
  • Color anodized aluminum actuator (Silver, Red, Blue, Purple, Black).
  • 3 lower ports and two top ports for easy install, no need to rotate the actuator top at all, plugs included for unused ports.
  • Ultra compact design fits in very tight spaces
  • V-Band inlet and outlet make install easy, flanges and clamps are in the box!
  • Integrated -4 AN water cooling ports that cycle a small amount of coolant through the actuator top to keep the temperatures down in extreme conditions such as road racing. These are leak tested after installation from the factory and can be removed if not utilized.
  • Extreme high temp casting available for Motorsport applications
Full information here - http://tialsport.com/index.php/tial-produc...stegates/39-mvr
No your not blind!
I'm also interested. I would like a photo of the serial number as there are heaps of fakes of these unfortunately.
Sorry guys the pricing part might have helped. These are brand new in the box, unopened. The picture you see is from another item which i sold a week or so ago i have a few of these for sale. If anyone wants individual photos or any other details let me know.
EDIT - These are 100% genuine.
