hi guys hea i have my 1998 r34 2 door with a few mods making 380hp on 16 psi 400hp on 18psi have dyno sheets etc.has 97k on the clock needs a few little things done but depends how picke you are car drives great was daily driven on 14psi.can be sold with a rwc for extra no rego. $$10999 is a CASH PRICE if you want to SWAP 14k
MODS LIST.
Garret GT35R Turbo
50mm Wastegate
Highmount maifold
4inch turbo back
Microtek LT12
Greedy oil cooler
super spark coil packs
555cc nismo injectors
Fmic kit
HKS bov
Teins super flex coilovers with in cab damper control
K SPORT 8 POT Brakes with 13inch rotors
18x10 lenso D1Rs
aftermaket rear camber arms
stage 2 shift kit (auto box)
apexi gauges
nismo side skirts and rear pods
cusco oil catch can
there is proble some i have forgot i am neg on the price if you want to no more about the car txt or call on 0434012067
on the gold coast qld
  • 3 weeks later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
