I can drive past 180kph on my car and a little over 190.[from my own judgement] after 190ish it wont go up anymore...
is that speed cut? but i doubt it as i imagine it to be just at 180 kph.
planning to get a RSM if mine really has a speed cut... of 190 that is...
feedback appreciated .
thanks
https://www.sau.com.au/forums/topic/439331-r33-speed-cut/
If you fit a motec exhaust it eliminates the factory speed cut. I'd probably look at a bigger top cog in the auto too mate. They are always pretty short hey.
While he's doing the top cog is it worth spending the extra to convert to flappy paddle?
https://www.sau.com.au/forums/topic/439331-r33-speed-cut/#findComment-7204386
yes im not from around here...
not that i really need it to go beyond 180... i just wanted to make sure mine has the speed limiter... but wasnt sure because i gets past 180...
Because your speedo is out by 10k's at 180.
https://www.sau.com.au/forums/topic/439331-r33-speed-cut/#findComment-7205484
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
