Wtb R33 Gtst Parts. Bonnet/headlights/front Bar/exhaust/speed Sensor/abs Relay/lighter/rubber Gear Boot
Hey,
Currently trying to source the following for my Series 1 R33 GTST.
- Bonnet (Preferably black or the navy blue colour)
- Headlights
- Front bar (Preferably black or the navy blue colour)
- Exhaust (Doesn't have to be complete, could be catback or just a front/dump pipe as I can mix and match)
- Speed sensor as my speedo stopped working
- Abs relay
- Cigarette Lighter unit as mine is empty so not sure what wiring is needed etc too
- Rubber shifter boot as mine is split underneath my shifter surround and I can smell gearbox fluid....... :(
- Front mount with piping
- R33 GTR front seats
Can text me on 0468 330 099 as its easier but I can check pms too... Willing to pick up anywhere In Sydney or within an hour or two from Sydney.
Edited by deva0o
I've got a newly sprayed black bonnet and jasma stainless cat back exhaust I could do both for $320 but I'm in Melb :( . Just on the off chance you were road tripping...
Thanks for that. Yeah unfortunately just looking locally.
  • 4 weeks later...
    • He is around but doesn’t really do automotive stuff anymore, mainly does commercial work now
    • Shortly after I do the usual full exhaust/ fmic/fuel pump/ R33 turbo and still get flogged at the lights by i30Ns
    • Is Chris from Craved Coatings still around? He is an ex SAU guy and did great powder coating (back in the day at least)
    • Bumping this thread yet again, has anyone ever tried putting yet another vacuum regulating valve on the hose that goes between the turbo inlet? Something local owners have mentioned is the Radium breather pipes de-restrict the valve cover but it actually produces an undesirable outcome in practice, way too much air is sucked out of the crankcase and a ton of oil comes with it as well. As far as I can tell the PCV diaphragm in these modern euro wet sump performance engines is active during boost as well, there's just a check valve to block boost from entering the valve cover and crankcase as there's no inherent check valve function in these diaphragm-type valves. Hopefully I'll be able to try some of this out soon. The Volvo XC90 4.4 V8 has a nice external version of these things.
    • So when will the Samsonas, twin scroll turbo setup on go?
