Selling my VspecII GTR if anyone is intersted.
This R32 GTR V specII was built in June 1994, so it is one of the very last to come off the line in Japan.
It has a JDM Do-Luck aero wivern body kit, 18x9” ROH Drift R alloy wheels and new tyres. V spec II comes with all the goodies. Brembo Brakes, Active LSD, Super hicase 4 wheel steering and Ohlins adjustable coil over suspension.
A’PEXi “power intake” dual funnel air cleaners, AVO adjustable cam gears, Garrett GT2860R ball bearing turbos, MiNES stainless steel exhaust. Timing belt changed at 90,000kms.
All so comes with Quik Trak QFC Mk III alarm, immobiliser, and tracking unit, Pioneer CD/Tuner, Sony explode speakers, N1 320km dash, AVO boost gauge, Momo race steering wheel, Nismo gear knob and GTR key.
Serviced by AVO and myself every 10,000kms this car was brought to Australia in 2000. Meaning it only spent 5 years in Japan. Very reliable good clean car first to see will buy. Included with the car is my Nissan Motor Company 400 page work shop manual.
http://www.carsales.com.au/private/details/Nissan-Skyline-1994/SSE-AD-2616549/?Cr=19&sdmvc=1
Jason.
Edited by GTR_VSpecII
https://www.sau.com.au/forums/topic/439348-4-sale-r32-gtr-vspecii/
Price drop. Need it gone.
Jason.
dude what posessed you to put such a hideous bodykit on a fine example of a r32gtr vspec? maybe if you pissed off the bodykit and returned it to stock you will sell faster. goodluck with the sale you'll need it.
  • Like 1
Agreed the body kit is a shocker, but if the seller doesn't have the originals - I don't see why he'd shell out several thousand to get a genuine nis one for a car he's trying to get rid of. Any serious buyer will offer him a bit less than the asking price to help facilitate buying a new kit themselves :P
For what the car is, it's a surprisingly good buy if all the info and pics are accurate. Just the kit makes my face hurt.
Hey guys.
The car came from Japan like this. It wasen't my first choice when buying a GTR but like thychiz says it was to good a car to pass up.
It means nothing but the Doluck type 1 kit can still be bought today from Japan. Unpainted unfitted the kit cost $8000.
I didn't like it at first but it grows on you.
Jason.
fair enough mate im glad to hear you didnt fit the kit. it wouldnt be hard to find a stock front bar and side skirts, you will find you will get a hell of a lot more interest if it looks stock.. i just sold my black 32 for $25k
and it wasnt a vspec and looked totally stock from the outside, good luck anyways
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
