Currently Wrecking R32, R33 And 180Sx In Brisbane
Wts
Bulk parts for r33/r32/180sx
Good rb25det gearbox - $950
Full r33 manual conversion - $1300
Full s13 manual conversion - $1000 brand new clutch
sr20det engine good runner no hotside or injectors - $1000
rb25det s1 engine good runner no turbo - $1000
rb25det suit rebuild - $350
Rear reo bars - $30 each
Rb25 s1 and s2 super spark coilpacks - $270 per set
Walbro fuel pump in s13/r32 cradle - $80
Garrett 3071r turbo setup - $1300
R32 front strut brace - $70
S13 rear strut brace - $70
R33 front strut brace - $70
R33 headlights - $170
R32 headlights no pairs - $80 each
180sx rear seats - $20
R32 passengers seat - $20
R32/r33 heater and ac boxes - $30 each
Misc speakers - $20 per pair
Ignitors/afms/cas - $60-$80
R32 sedan genuine skirts and pods - $500
R32 sedan vertex skirts - $150
R33 front bar - $100
R32 coupe full kit veilside style - $250
R32/r33 5 bolt shafts - $100
S13 3x2 bolt shafts - $50
S13 catback exhaust - $150
R32 coupe boot lid - $60
R32 coupe rear bar - $60
R33 coupe rear bar - $50
R33 steering rack - $70
R32/r33/s13/s14 stock suspension arms - $20 each
Lots of gauges from $30 each
Turbo timers from $20 each
Gfb boost tee - $40
Npc rb25 lightened flywheel - $150
Stock rb25det flywheel - $70
Momo course steering wheel - $100
R33/r32 front guards - $50 each
R32/r33 parcel trays - $50 each
Rb20/rb25 engine parts heaps of bits – from $20 each
Rb20/25 top mount manifold with external gate - $200
Rb26 injectors - $170
180sx hatch mint - $150
180sx doors - $30 each
S13/r32 window motors - $70 each
R33 rear windscreen - $60
Pod filters – from $20
180sx tail lights - $70
R33 tail lights - $70
Lots of interior bits from $20
R33 front seats - $70
S13 front seats - $50
R33 radiator - $70
R33 catback exhaust x3 - $150 each
Rb25det s1 engine looms - $130
X2 rb20det gearboxes one with broken 2nd one with broken 5th - $100
R33 tail shaft - $100
R33 door shells - $30 each
door cards - $20
lock and ignition sets - $150 each
boot linings - $60 each
Rb starter motors - $50 each
please contact 0420 767 957 or pm me (mobile preferred)
this is only a small portion of whats available if you need something just ask
springwood 4127
but can post
Edited by Sifty33
no speaker covers if thats what your meaning? they all have holes for speakers... the r33 ones I have come with covers but not r32
triptych I dont have them sorry... slickyr33 are you after a front mount kit with piping?
contact me on 0420 767 957 for a faster response :)
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
