For sale: Rays TE37 (circa 2005)
Price: $2100
Condition: Used - Professionally refurbished.
Other Info: I had the wheels fully refurbished, which included removing any known buckles, machining the lip, and full respray in a custom colour, which is as close to the TE37sl Pressed Graphite colour.
I also had new wheel stickers made up, and also purchased Rays stickers to make them resemble te37sl's
Love the wheels, nothing wrong with them at all, Just want a change.
Specs:
5x114.3
17x9 +15
17x9 +/- 0
235/40 all round, about 80% tread.
Car is driven every 5th week, due to my work style FIFO
Contact Details: here PM
11dd03b0-c6ee-4c6b-bf27-fa9f7b3ef441_zps
295473e2-1987-418b-941a-812ad5402245_zps
2be4f2f0d4768b6b98a253d96af37399_zpseb30
https://www.sau.com.au/forums/topic/439377-wa-rays-te37-17x9-15-17x9-0/
  • 2 months later...
  • 3 months later...
  • 3 weeks later...
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
