Hey guys up for sale is my black r33 GTR 95 model with 110xxx ks
Briefly about the car was purchased for myself to modify but unfortunately circumstances have changed, the car is immaculate inside and out it was
well taken care of by previous owner who was a older guy, the car has minimal wear and tear, few scratches on the paint which is normal for a car that age!
small and subtle modification list includes
-Tein fully adjustable coil overs
-3inch HKS cat back
- Clutch replaced
-apexi pod filters
-nismo gearnob
-speakers and head unit upgraded to kenwood
The car is a great base to modify or enjoy as it is, the car has hasn't been thrashed or had a hard time the factory boost restrictor still remains, and just had a service to
car will come with full year rego and rwc for 18,500 ono
location Melbourne
P.M for more photos
Sam 0401938623
https://www.sau.com.au/forums/topic/439403-r33-gtr-factory-black-immac/
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
