Cobb Of The Shelf Maps For 98 Oct?
You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
Not the headlight. It's the DRL that serves double duty as white and amber. Would be the easiest way to make it happen, if fitting a BCM was in any way an easy thing. Otherwise you'd do it with some relay logic and/or maybe some diodes.
Would require a very smart body control module which these cars are about 20 years to old to have
Sounds like using one of those configs modern cars use where they turn off the whole headlight these days on the side that the indicator is flashing on.
