Item:
Panasonic VIErA TH-P42S10A 42" Full HD Plasma TV
42"/106cm Plasma TV
Full-HD Plasma Panel
550Hz Sub Field Drive
Integrated High Definition Digital DVB-T Tuner
2,000,000:1 Dynamic contrast ratio
3 x HDMI inputs
VIErA Image Viewer
SD Card slot
VIErA Link
Technical Specifications:
Screen Size (cm viewable): 106
Screen Size (inches viewable): 42
Screen Type: Plasma
Width (mm): 1029.00
Height (mm): 704.00
Depth (mm): 334.00
Panel Type: Progressive Full-HD Plasma Panel
Panel Aspect Ratio: 16:9 (Widescreen)
Aspect Ratio Control Modes (TV/AV modes): 4:3, 4:3 Full, 14:9, 16:9, Just, Zoom1, Zoom2, Zoom3, DTV: 16:9 & 4:3 Full
Aspect Ratio Control Modes (PC mode): 16:9, 4:3
Comb Filter: Yes
Progressive Scan: Yes
TV Tuner Receiving System: DVB (Digital), PAL-B/G (Analogue)
Tuner Type: Integrated SD/HD DVB-T 7MHz Australia, PAL B/G
Electronic Program Guide (EPG) Support: Yes - 7 Day
Channel Preset/s: -
Colour System: PAL, NTSC
Picture In Picture (PIP): No
Multi-Window: PAT
CATV/Hyperband Tuner: Yes
Stereo: PAL 2CS Stereo
Horizontal Resolution (pixels): 1920
Vertical Resolution (pixels): 1080
Contrast Ratio:1 - Dynamic: 2000000
Picture Adjustment Modes / Film Modes: Normal, Dynamic, Cinema, Eco, Game
Colour Temperature Control: Normal, Cool, Warm
Picture Quality Improvement Functions: 24p Film Playback, 3D Colour Management, 3D Comb Filter, Sub Pixel Control, Motion Pattern Noise Reduction, C.A.T.S. (Contrast Automatic Tracking System), Video Noise Reduction
Audio Output Power - Total (Watts RMS): 20
Speakers: 2
Audio Features: Virtual Surround Sound, Bass/Treble, Balance, Headphone Volume
Auto Timed On/Off Switch: Off Only
On Screen Display Languages: English
DTV Parental Guidance Info: Yes
Remote Control: Standard
SD Card Slot: Yes, SDHC Compatible
Component Video Input: 1
Applicable Component Video Input Signals:
- 576i @ 50Hz (15.63KHz)
- 576p @ 50Hz (31.25KHz)
- 720p @ 50Hz (37.50KHz)
- 1,080i @ 50Hz (28.125KHz)
- 480i @ 60Hz (15.73KHz)
- 480p @ 60Hz (31.47KHz)
- 720p @ 60Hz (45KHz)
- 1,080i @ 60Hz (33.75KHz)
HDMI Input/Output: x3
Applicable HDMI Video Input Signals:
- 1,080p @ 50Hz (56.25KHz)
- 1,080p @ 60Hz (67.5KHz)
- 1,080/24p @ 24Hz (27KHz)
S-Video Input: 1
Combined I/O Scart Terminal(s): -
PC Input: Yes, 1x VGA (15 pin Mini D-sub)
Applicable PC Input Signals 4:3 ASPECT RATIO:
- 800×600 @ 60 Hz (37.88KHz)
- 800×600 @ 75 Hz (46.88KHz)
- 800×600 @ 85 Hz (53.67KHz)
- 1,024×768 @ 60 Hz (48.36KHz)
- 1,024×768 @ 70 Hz (56.48KHz)
- 1,024×768 @ 75 Hz (60.02KHz)
- 1,024×768 @ 85 Hz (68.68KHz)
- 1,280×1,024 @60 Hz (63.98KHz)
- Macintosh 13 inch 640x480 @66.67Hz (35KHz)
- Macintosh 16 inch 832x624 @74.54Hz (49.72KHz)
- Macintosh 21 inch 1152x870 @75.06Hz (68.68KHz)
A/V 1: Audio/Video-in
A/V 2: Audio-in, Video-in, Component Video Input [Y, Pb, Pr]
A/V 3: Audio/Video-in, S-Video-in
A/V 4: Audio/Video-in
Digital Audio Out: Optical Terminal, DVB-T Only
Monitor Out: Stereo L&R [RCA], Video (CUBS) [RCA]
Headphone Jack: Yes, 3.5mm Stereo, Side
Operating Temperature Range - Minimum (degrees C): 0
Operating Temperature Range - Maximum (degrees C): 35
Operating Humidity Range: 20% - 80%RH (non condensation)
Pedestal Stand: Supplied as Standard
Swivel Stand Operation: No
Star Rating: 2.5 Stars
Normal(Home): 194
Standby Active: 17
Standby Passive: 0.4
Item Condition: Used but in very good condition. Have owned the TV since new.
Reason for Selling: This may be a long shot due to this TV being a discontinued model, more of an EOI to see if any one would be interested in purchasing this TV, or may consider swapping for something of interest. Have now upgraded to an LCD TV.
Price: Make an offer
Contact Details: David, 0401233113.
Pictures
Edited by dave88
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
