hey guys I been looking at different things with my r33 and I relized all spoilers look shit on an R33 flat back is best and then I looked at the front and thought hmmm a nice twin round headlight conversion would look nice and then it got me thinking ive seen cefiro and R32 R34 fronts on an R33 but what about a 370z front end I reckin it wouldn't look too bed aye.
its a fat car like the R33 is really no other skyline has the fatty dynamics like the whale body r33 wide front gaurds with the lighst going up I reckin would look kick ass.
what you guys think cant find anything on the net yets still looking so either it looks shit or im 1st to think about it lol.
https://www.sau.com.au/forums/topic/439440-370z-front-on-an-r33/
yer I know unique usally mean ugly but I dunno somthin about it makes me want to try it out I mean would look good as a drift car and honestly that pic makes me want to do it even more lol
id think of buying a damn 370z or even Q35 skyline non gtr But the thought of non RB non turbo just kills it.
V6 I can cope with but damn Non Turbo and non Hot plate lights whhyyy Nissan.
Edited by HYBRID VL
Yer I asked a engineer about that he said that the size of the motor is np even an RB30 though the age of the motor compared to the age of the car it cannot legally be done.
Something about pollution standards this is why 13B rotaries aren't slotted into RX8 this is what he said this is only from one engineer that is a mates mate I havnet asked anyone else about it.
I also like the 3500cc compared to even a 2600cc even though the RB26DETT has a heap more power.
What is the engine like with a turbo or 2 strapped to the sides and what about the manual boxes in the Q35's will they handle the added HP of a turbo same as engine?
Any engine with a turbo strapped to the side is the same as before, just now there is a turbo strapped to it.
Rather than going to the trouble of strapping it to the side for no real gain, a turbo conversion would be more useful and no straps required.
Ok look il take the negative comments and all that and stupidity intwined with this project I was asking about but don't insult my intelligence with your smartass comments so much you needed to post twice I was simply asking if you don't ask you don't know.
your last comment is kinda redundant as your contradicting yourself as saying a turbo conversion as what its the same as before what you mean just no plumbing and ECu and all that aswell do I have to write all that in aswell meaning
turboing the NA motor that is in the Q35 do you mean swap the motor out for a V6 twin turbo motor from say an R35 GTR as they are my simplest options im guessing not as cheap as I would expect but that's what I would do if I was to get a Q35?
Don't just jump in enlighten me please.
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
