Thinking parting out my 33 4 door. Depending on interest, rough parts list as follows. Will only start to strip when I get deposits etc
RB25DET Neo 87***kms
1.7mm metal headgasket
Gate racing timing belt (5000kms old)
Water pump (5000kms old)
Tomei adjustable cam gear, exhaust
Fresh ACL bearings $2000
Highflow Rb25 injectors 550 or 660cc will check $400
Hks Oil Cooler with oil filter relo $500
Hks return flow intercooler, with Hks BOV $650
Splitfire coil packs (5000 kms old) $400
Alloy rad holds a lot of coolant with silicone hoses $225
Exedy hyper single clutch n flywheel plenty of meat (5000 kms old) $450
Highflow turbo 3076 with larger rear housing, garret core, braided oil/water lines, Neo front housing cost $2470 made 248 rwkws on 13psi $1400
Hks hard inlet pipe $120
Standard RB25 Afm with plug $75
Rb25 loom series 2 $250
Z32 nistune Ecu so you can run Vct still $550
Manual convo kit minus gearbox and clutch or buy the clutch as well $250
Standard R200 diff $150
Tein Super Street Coils, no knocks mint $750
Tein castor rods $180
Stock Shocks/Springs $200
Standard wheels with 1000km old tyres $350
Hicas lock bar jap brand good quality $100
3 inch stainless front n dump pipe $150
Full 3 inch stainless cat back with highflow cat $450
Shell has rego just expired, silver make and offer will be rolling BYO wheels. No brakes
Series two headlight couple cracks still worked fine missing a clip $270 for the pair
Series 2 taillights one cracked and centre piece $175
Series 1 taillights and centre piece $75
Doors $100 bare door, $150 with interior and electric window assembly
Guards $100 each or $175 pair
Bonnet $150
Boot has spoiler holes $75
Front bar with front viva lip has cracks in it $175
Rear pods $100
Skirts $100
Front Window $100
Rear Window $125
Starter Motor $75
Steering Wheel $100
Auto Dash Cluster $50
Seat Belts $75 each or $200 the lot
Seats $50 each
All other bits just Pm me
Wheels, Brakes and gearbox soldpost-86415-0-89614200-1392881185_thumb.jpgpost-86415-0-89614200-1392881185_thumb.jpg
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
