Thinking parting out my 33 4 door. Depending on interest, rough parts list as follows. Will only start to strip when I get deposits etc
RB25DET Neo 87***kms
1.7mm metal headgasket
Gate racing timing belt (5000kms old)
Water pump (5000kms old)
Tomei adjustable cam gear, exhaust
Fresh ACL bearings $2000
Highflow Rb25 injectors 550 or 660cc will check $400
Hks Oil Cooler with oil filter relo $500
Hks return flow intercooler, with Hks BOV $650
Splitfire coil packs (5000 kms old) $400
Alloy rad holds a lot of coolant with silicone hoses $225
Exedy hyper single clutch n flywheel plenty of meat (5000 kms old) $450
Highflow turbo 3076 with larger rear housing, garret core, braided oil/water lines, Neo front housing cost $2470 made 248 rwkws on 13psi $1400
Hks hard inlet pipe $120
Standard RB25 Afm with plug $75
Rb25 loom series 2 $250
Z32 nistune Ecu so you can run Vct still $550
Manual convo kit minus gearbox and clutch or buy the clutch as well $250
Standard R200 diff $150
Tein Super Street Coils, no knocks mint $750
Tein castor rods $180
Stock Shocks/Springs $200
Standard wheels with 1000km old tyres $350
Hicas lock bar jap brand good quality $100
3 inch stainless front n dump pipe $150
Full 3 inch stainless cat back with highflow cat $450
Shell has rego just expired, silver make and offer will be rolling BYO wheels. No brakes
Series two headlight couple cracks still worked fine missing a clip $270 for the pair
Series 2 taillights one cracked and centre piece $175
Series 1 taillights and centre piece $75
Doors $100 bare door, $150 with interior and electric window assembly
Guards $100 each or $175 pair
Bonnet $150
Boot has spoiler holes $75
Front bar with front viva lip has cracks in it $175
Rear pods $100
Skirts $100
Front Window $100
Rear Window $125
Starter Motor $75
Steering Wheel $100
Auto Dash Cluster $50
Seat Belts $75 each or $200 the lot
Seats $50 each
All other bits just Pm me
Wheels, Brakes and gearbox soldpost-86415-0-89614200-1392881185_thumb.jpgpost-86415-0-89614200-1392881185_thumb.jpg
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
