Hi!
Does anyone have any good info or guide to a RB26 vct build/setup.
Im currently building a RB30/26 here in Sweden and going for around 500whp on E85 with a high comp setup, and looking in to do a vct build if it's not at a NASA level of build..
Looking to make the engine as responsive as i can without going for at 3.4L kit..
//Jesse
https://www.sau.com.au/forums/topic/439457-rb26-vct-build/
No, not the HKS system that costs more than my car, i have seen people using the rb25 stock nvcs on the rb26.
No one in Sweden have done it, and it's very little info about it on the web about the actual swap more than it can be done...
https://www.sau.com.au/forums/topic/439457-rb26-vct-build/#findComment-7206287
With an RB30 unless it's a total pig should smash 500HP on E85 with the right turbo/s.
Don't quote me on it but I read somewhere that even the HKS V Cam setup only increased performance marginally.
https://www.sau.com.au/forums/topic/439457-rb26-vct-build/#findComment-7206732
  • 6 months later...
and was some talk here about using 25 vct parts, I think elite racing/the dan was doing something if you want to read through
http://www.skylinesaustralia.com/forums/topic/251820-got-over-400kw-atw/page-51
The Dan stoped responding my PM:S and did not give away any info (i said i was willing to buy all the parts from elite racing but doing the machine work on the head myself du to de freight cost sending my head from Sweden to AU and back again..
But still on square one so if anyone have any Good input on cam choice etc i would be happy..
https://www.sau.com.au/forums/topic/439457-rb26-vct-build/#findComment-7384920
VCT will only give you 20 degrees correct?
Vcam uses the VQ35 hydraulic actuator, usually giving 40 degrees, but Nismo made a modified 50 degree setup for it. If you can get that to work, as in not hit the valves on pistons, it will give some pretty good midrange gains over VCT I imagine.
https://www.sau.com.au/forums/topic/439457-rb26-vct-build/#findComment-7388912
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
