Hey guys,
In the process of completely stripping down a white 1996 R33 GTST series II located in Townsville. Heaps of parts up for grabs so if you want something specific let me know.
Would prefer local pickup but small parts I don't mind freighting.
Some prices and parts include:
Aftermarket parts
Aftermarket billet fuel rail - $50
Built long block engine (refer to my other for sale thread on the engine alone) - $7000
Garret GT3540 1.06 exhaust housing, 6boost, tial gate, screamer, dump pipe, intake pipe and K&N filter (refer to my other for sale thread on the turbo kit alone)- $3000 (or can split up)
Splitfire coilpacks (S2 GTST and R34 GTR) - $400
Tial BOV on intercooler pipe with v-band flange - $250
Greddy front mount and intercooler piping - $400
Greddy gear knob - $40
Autometer cobalt AFR gauge - $50
Front aluminium strut brace - $75
Fibreglass rear bumper (unknown brand) - $100
Boss kit - $50
3.5" X-force exhaust system with Varex muffler and decat pipe - $500
Rockford Fosgate 6.5" component speakers - $100
Rockford Fosgate 6.5" coax speakers - $80
Surge tank with Bosch 044 fuel pump and lines - $300
OEM parts
5 speed manual with Exedy twin plate clutch (worth over $2000 alone) - $2000
Front and rear brakes with DBA slotted rotors, brake lines and EBC Red Stuff Pads - $1000
Alternator - $75
TPS - $50
Starter motor - $60
Power steering pump - $60
A/C condensor - $100
A/C compressor - $100
LSD diff - $200
OEM suspension - $150
Master cylinder - $50
Stock wheels with tyres (6 available) - $50 each
Series II headlights - $400
Series II front grille - $100
Driver's side mirror - $50
Bonnet - $200
Driver's rear tail light - $70
Front Seat belts - $80 each
Rear Seat belts - $80 for all
Front guards - $80 ea.
Doors - $200 ea.
Door cards - $150
Passenger side window switch - $50
Centre console with armrest - $80
Intank fuel pump - $40
ABS module - $50
Drivers airbag - $50
Passengers airbag - $50
Door glass - $80 ea.
Heaps of other parts available just hit me up. More than welcome to come and have a look at parts first. Let me know if you need a photo of something.
Also chasing $500 ONO for the bare metal shell of the car.
Thanks guys.
Phil
Hey Phil,
Was wondering if you could send me some pics of the GReddy Gear Knob and Series 2 Headlights please. Can text through to 0400215126
Cheers Josh
Hey Phil,
Cheers Josh
Can do man.
Any difference with the billet fuel rail vs stock? I went through your list, but do you have a aftermarket ecu? Cheers OJ
The billet rail is made for top feed injectors as opposed to factory side feed injectors.
I had a Link ECU however that has been sold.
  • 3 weeks later...
  • 1 month later...
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
