OK this might be abit silly but i wanted to clear it up.
i have 3" cat back on my s2 stag no mufflers other than a cannon and 3" front pipe to a split dump (2 piece)
the issues is the 2.5" cat is still there does this defeat the purpose... will i see much power or will the cat restrict the shit out of it.
other mods i have are - Turbotech valve @ 10psi
- k&n pod with heat shield
- turbosmart kompact plumb back (stock one was stuffed)
the car still feel sluggish or i that just the auto
thanks
https://www.sau.com.au/forums/topic/439491-exhaust-question/
1. RandR
2. Hot air intake
3. hmmmm..
4 speed auto
2T wagon+2.5lt engine= a little sluggish to start with.
last issue you will have is a 2.5" pipe being a restriction at that power level.... must be droney as buggery.
Cheers
J.
Cheers
Justin
  • Like 1
Yuh....big exhaust doesn't really "unleash" any extra power. Maybe a few kW between std and a complete 3". The biggest benefit will usually be felt with it coming on boost a bit quicker. What a big exhaust is for, is for allowing you to add a bunch of power via other mods, and still get the exhaust gas to go where it's supposed to.
FWIW, there is little point having a 3" exhaust with the stock cat. Get a decent cat in there, even if for no other reason than the original one probably being buggered anyway.
thanks for the reply
how do you eliminate rich and retarded?
Ive heat shielded the pod or is a pod a huge issue with rb25's?
stage 2 shift kit come up soon =)
The std RB25 ECU sucks balls. The only way to avoid R&R is to not wind the boost up very far, or piss the ECU off and replace with something that won't do it (Nistuned Z32 ECU or and aftermarket ECU).
Pod filters just suck hot engine bay air. Heatshields do pretty much noting unless the only air inlet to them is from outside the engine bay.
You might hit R&R at 10. It might start with almost no boost increase at all.....depends on lot on what other flow enhancing mods the car has and how precious the ECU is.
R&R is nothing more than excessively rich commanded fuelling in cells at higher than normal loads in the map and very retarded timing values at matching loads in the timing map. At normal loads the mixtures in the R33 ECU are bad enough - easily getting down to 11 or less. As you push deeper into the map the commanded mixtures go horrible. The commanded injector pulsewidth is well over 100% (so they just stay open and spray!). As soon as you raise the boost (or really, the flow) of the engine at all you start working into the R&R region and it just gets worse as you go. There is a reasonably large step into alarmingly bad R&R that does come in at around 10-12 psi on most cars. That's what people call R&R, but it's really just accessing the next row in the map and that row has even more terrible numbers in it.
I appreciate the fact that you always take the time to explain what R&R is GTSboy. I think I have now read about 7-8 different explanations on what it is from you and always tailored to the OP's question.
As someone who was in the same position as some of these people not long ago it really is very helpful.
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
