Awesome build thus far mate!
Keen to see when the engine is done.... eventually :P
Just a quick query, I notice you are running a Mishimoto Radiator.
I'm actually looking into getting one! Just wondering if they are truly a "Direct Fit" and the quality and results of them?
As opposed to going KoyoRad
Cheers! :cheers:
Honestly i couldn't say how well it does, i have done like 50km with it in haha
In saying that i have had no issues with it, looks good and it does what it's supposed to lol and yes it bolted right in perfectly.
That's enough convincing for me haha!
I have read really good reviews about them and another member of this page has just stated they were good for him too
So looks like I'll be buying one!
Cheers for help man! :worship:
Cheers! :cheers:
Changed my mind regarding the IQ3..
Found something that screams Anfanee that will keep in line with what i want the car to look like.
However finding said part in good condition............Let the search commence!!
P.S i'm still looking for a bloody centre console... lol....
They will replace the standard ones, But i won't monitor boost or Battery temp.
Will do water temp, Oil temp, and Oil pressure.
Still trying to track down the boost gauge i want. Proving hard to find.
get a fuel pressure gauge also Anf
buy mine and sell yours for parts
you'll save money :P
comes with Nismo rims, intake manifold and key :)
Edit: Well you would have before engine build and buying spree, bit late now !
Edited by Sinista32
ive got a zd that does everything except boost.attachicon.gifimage.jpgattachicon.gifimage.jpgattachicon.gifimage.jpg
A little too Blingy for me. I'm OCD with how much i hate gauges and stuff in the interior.
Even putting a boost gauge in the vent is annoying me.
what if nismo made an R32 GTR fuel pressure gauge ;)
They do. But i don't want to fill my interior up with shit. It's not a racecar.
If i had the money S!n i would.
I still want your center console. Farken sell me that.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
