  • 4 weeks later...
Updates time.
Gave her the fastest bath of her life. And a quick cover with Zaino.
Still need to fix the drivers headrest of the nismo covers. And give the interior a clean......
So... How to tell i like nismo? Also i just noticed i need to straighten the horn... lewl There is also a Nismo boost gauge in the circle vent... Missed that in the pic.
Will get some decent shots when i can....
  • Like 2
I'm still doing short term oil changes, will swap to a genuine filter when it's been driven a bit more.
Next order ill order another nismo sock for the oil filter....
Also looking into options for the battery. Possibly a stand+enclosure welded up.... at the moment it's literally propped up with wood hahahaha
Few questions...
The black fuel line that runs over the plenum.. Should i braid that for the lulz?
Also considering either braiding or getting one of the old school greddy hard pipes for the top Rad hose...???
I finally managed to get my hands on a decent condition optioned up foot rest, and i didn't have to pay drug (nismo) money for it. Pretty stoked. When that arrives that means the interior is pretty much done. Unless as stated above i want a nismo cluster and/or the optioned knee pads.....
Gearbox has a slight crunch 4th syncro.
Or new diffs? !!
  • Like 1
Just now, ActionDan said:
Tip all of that money you might spend into my car instead, know that it went to a good cause?
I'll tell you what, you give me the car and ill spend all the money on it.
An interesting counter offer....
The car did come from Canberra actually, maybe it was always meant to be yours.
As for your list, I would rebuild box. Reliability/avoiding further damage over upgrades IMO.
Edited by ActionDan
22 minutes ago, Robzilla32 said:
Why Quaife instead of Nismo at the front?
A lot of ppl seem to prefer them over the Nismo. I'm not sure why as the reasons they specify it sounds more like a setup issue personally.
Personally I've been in a couple of cars with Nismo front diffs setup correctly by RPM and they were fine after run-in.
I'd do transfer case mod>front diff> rear diff (in that order)
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
