RB20DET
Manual
Black
133,541 km
First owner in Australia, I imported the car in 2004
Stock interior in good condition
Factory fitted sunroof
Paint is in average condition, front bumper is scratched
Intermittent hesitation on startup, throttle needs a blip. Most likely carbon build up in the idle air control valve. Easy fix.
Registration expires Jan 2015
Price: $7500 (negotiable) with RWC
Contact: Ray on 0414 420 375 or PM
Modifications
Engine:
Cooling Pro front mount intercooler
R34 Series 2 Turbo running 13psi
3inch Flying Performance dump pipe
3inch HKS Silent High Power Stainless Steel Cat back exhaust
Hi flow cat
Apexi pod filter
Dr Drift ECU Remap
Turbotech Boost Controller
Walbro Fuel Pump
Suspension/Brakes:
New RDA slotted/dimpled rotors front and rear
New Remsa brake pads front and rear
Nolathane camber adjustable front control arm bushes
Front strut brace
Exterior:
18x8 inch DTM wheels
HID Xenon Headlights
LED Parker Lights
Interior/Stereo:
Autoguage Oil and Boost Pressure Gauge
DEI Viper alarm with remote start, window wind up/down and remote boot release
Sound deadened doors
Pioneer 12inch subwoofer 400WRMS
6.5inch Jaycar Precision Response Kevlar Splits front speakers
6inch Pioneer rear speakers 30WRMS
Jaycar Response Amplifier 4x130WRMS
JVC Headunit
Blue LED cluster and HVAC control
White LED Interior lights
Edited by stingray
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
