Hi Guys, I am new to the forum and have just bought an R32 GTR.
1) I know that rwkw is the important figure but I am interested to know what my power might be at the engine (just for a basic comparison to manufacturer specs).
R32 GTR DD Dynoed at 200kw at wheels (as far as I know standard with just a 3 inch nismo exhaust and running 10psi boost).
2) any ideas on expected quarter mile times and 0-100kmh times with 200kw at wheels R32 GTR.
thanks in advance
https://www.sau.com.au/forums/topic/43953-gtr-powertrain-losses/
thanks in advance
1)I suspect probably a 25-30% loss through the drive train, so 200RWKW is somewhere like 250-260KW at the flywheel.
2) 4.5 sec 0-100 and maybe 12.6-8 with a good clutch.
I don't think a "%percentage" value is fair & accurate eg: Today I make 210kw at the wheels and loose 30% from my engine to the wheels =90kw drivetrain loss.
But if my drivetrain remains the same and I make 300kw at the wheels.. then why would my drivetrain loss be more??
SydneyKid had some facts when they engine dyno'd a car & then put the car on the dyno, and If I recall correctly there was about 70-80kw drivetrain loss from engine to wheels for a GTR, this figure differed for a GTsT.
Yep what meshmesh said - % isn't really right, because why would it loose more when you increase power (ok it maye loose a few kw more due to extra heat etc... but not a %)
I remember reading SK's thread as well explaining it, try and find that :)
I had a talk about this with some mechanical engineers, there is both a fixed loss and a percentage loss that make up the total loss.
Ahh yes, but the percentage loss is a low percentage. :headspin:
Plus you need to remember that energy can neither be gained nor lost (Newton), it is simply transformed into other forms of energy. In this case, basically heat. So you need to ask yourself, where does all that extra heat go?
To answer JayDee's original question, the 4wd losses are around 70 rwkw at standard power. BTW the 206 kw is a bit of a furphy :bs!: I reckon it's more like 226 kw for an R32 GTR.
PS; Yes, I know about E=MC2 (Einstein) but I assume no atomic reactions when doing my power loss calculations :microwave
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
    • Been a long while since i have updated this money pit lol.  Have had a few tune related issues with the car, first blowing the frost plug out the back of the head and then blowing the headgasket 3 months later, which has now been retuned and sorted. Done a few little changes along the way as well, i wasn't happy with the wheel and brake setup, so start of last year i managed to get myself a set of r35 brakes and nismo lmgt4 18x10.5 +15 Upgraded to now running a Precision Gen 2 6870 with a 1.15ar, to be honest felt more like a downgrade as the car feels much lazier around town compared to the Gen2 6466 previously. 0761719E-5683-43F7-BD3B-4BD94335DFF4.mov
    • Hi there, i am currently using the Elmers Racing Billet merge collector, we are using sch40 tubing and 1.5" ID, no cracks so far. however if i was to do it again, i would go sch10 with 1.25" runners
    • I haven't touched the turbos so might need to look at that 👍 Appreciated 🙏
    • If you haven't replaced the OEM turbos, replace them sooner than later. I have seen recent pictures of what OEM ceramic turbo failure can do in an RB26 and it will make a 10k AUD budget look like a joke. Single vs twins have been done to death on this forum. If your turbos haven't fallen apart you can probably send yours off to Hypergear for rebuild. The journal bearing option will have more turbo lag but it's a good bit cheaper. I would probably go for ball bearing CHRA but keep in mind ball bearing turbos are more particular about oil pressure/flow.
