Hey guys, up for sale is my much loved r33 m-spec!
I have pics in my gallery if u want to have a look,
I'm asking for $11,000 cash however I've put at least 4 times that into it!
It's is also advertised on gumtree ID #1031221970
https://www.sau.com.au/forums/topic/439551-94-gtst-m-spec/
Over $50k spent on this car,
Must sell ASAP, going overseas!
All offers will be considered !!!!
94 r33 gtst m-spec,
everyday drive tune on BP Ultimate 476.5bhp running 16psi at PITS on gold coast,
engine fully rebuilt less than 8000ks ago,
over sized CP forged pistons,
Spool rods,
oversized s/s valves,
solid lifters,
tomei drag racing cams 272deg rotation with 10.25mm lift
all tomei gear in the head,
adjustable cam gears,
nitto oil pump,
nismo thermostat,
Greddy timing belt,
nismo 740cc injectors,
plazmaman plenum,
ARP main, head studs & rod bolts,
ACL main, big end & thrust bearings,
engine balanced,
head ported,
JJR cooling radiator,
Apexi AVCR boost controller,
Autronic computer,
CDI coil pack & computer,
Garret 35/82 ball bearing turbo
6boost high mount manifold
50mm turbo smart external waste gate, not plumbed in to exhaust ( 2' screamer pipe)
3' exhaust from turbo down to flexible joint and back to 5' Apexi cannon,
Bosch 040 fuel pump in tank, 4ltr surge tank & 1000hp fuel lab prodigy fuel pump in boot
heavy duty HSD coil-overs,
strut tower braces front & rear,
custom heavy duty modified gtr clutch!!
CAR is rego but sell unregistered as not rwc, very loud, fummy, has some electrical faults (nismo 300km dash cluster not working correctly speedo not working, I still have the original dash cluster which was working fine when I swapped it over, front window wipers stopped working a few months ago, drivers door window doesn't go up every time!
VERY FAST with heaps of power under your foot!!
RWC just needs some noise reduction mods to exhaust, and some auto electrical wiring repaired or original dash cluster re-installed
Regretful sale, If you want to know any more about it please feel free to message me.
Must sell
Price drop $11,000.00 or make me a cash offer!!
Have receipts and dyno sheet for all work done and TRUE BHP, it has not been dragged or drifted since I've owned it (2008), it isn't a show car, has a few little scuffs, dings ect however it is a go car!!
Will consider Swap/trade plus cash my way for a Stagea/Legnum, skyline sedan,Vr4, wrx or dual cab ute that has child restraints in back of lesser value!
https://www.sau.com.au/forums/topic/439551-94-gtst-m-spec/#findComment-7207541
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
