Hey guys, up for sale is my much loved r33 m-spec!
I have pics in my gallery if u want to have a look,
I'm asking for $11,000 cash however I've put at least 4 times that into it!
It's is also advertised on gumtree ID #1031221970
https://www.sau.com.au/forums/topic/439551-94-gtst-m-spec/
Over $50k spent on this car,
Must sell ASAP, going overseas!
All offers will be considered !!!!
94 r33 gtst m-spec,
everyday drive tune on BP Ultimate 476.5bhp running 16psi at PITS on gold coast,
engine fully rebuilt less than 8000ks ago,
over sized CP forged pistons,
Spool rods,
oversized s/s valves,
solid lifters,
tomei drag racing cams 272deg rotation with 10.25mm lift
all tomei gear in the head,
adjustable cam gears,
nitto oil pump,
nismo thermostat,
Greddy timing belt,
nismo 740cc injectors,
plazmaman plenum,
ARP main, head studs & rod bolts,
ACL main, big end & thrust bearings,
engine balanced,
head ported,
JJR cooling radiator,
Apexi AVCR boost controller,
Autronic computer,
CDI coil pack & computer,
Garret 35/82 ball bearing turbo
6boost high mount manifold
50mm turbo smart external waste gate, not plumbed in to exhaust ( 2' screamer pipe)
3' exhaust from turbo down to flexible joint and back to 5' Apexi cannon,
Bosch 040 fuel pump in tank, 4ltr surge tank & 1000hp fuel lab prodigy fuel pump in boot
heavy duty HSD coil-overs,
strut tower braces front & rear,
custom heavy duty modified gtr clutch!!
CAR is rego but sell unregistered as not rwc, very loud, fummy, has some electrical faults (nismo 300km dash cluster not working correctly speedo not working, I still have the original dash cluster which was working fine when I swapped it over, front window wipers stopped working a few months ago, drivers door window doesn't go up every time!
VERY FAST with heaps of power under your foot!!
RWC just needs some noise reduction mods to exhaust, and some auto electrical wiring repaired or original dash cluster re-installed
Regretful sale, If you want to know any more about it please feel free to message me.
Must sell
Price drop $11,000.00 or make me a cash offer!!
Have receipts and dyno sheet for all work done and TRUE BHP, it has not been dragged or drifted since I've owned it (2008), it isn't a show car, has a few little scuffs, dings ect however it is a go car!!
Will consider Swap/trade plus cash my way for a Stagea/Legnum, skyline sedan,Vr4, wrx or dual cab ute that has child restraints in back of lesser value!
https://www.sau.com.au/forums/topic/439551-94-gtst-m-spec/#findComment-7207541
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
