Sorry if wrong area
Google hasn't showed me much, I want to move my r32 ps reservoir to where the charcoal canister is, I can mount it fine , but does the bottom of the ps reservoir need to be highe than the pump? Or does the bottom orthr fluid level in the resi have to be higher? When I mount it the resi bottom is roughly in line with the top of the pump, but the main hose going to the pump is on a slight up angle
Would rather not cook a ps pump if I can
Any links or info/ pics is appreciated, I may have missed it on google/forums, not sure though, most were useless
https://www.sau.com.au/forums/topic/439587-r32-ps-reservoir-relocation/
Here is a pic of mine relocated to the where canistor was before ive got no problems(its has the sock cover on it). I also did run a 90 degree barb fitting off the pump in order to not kink the hose as it can get pretty hard to re route it to the front.
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
