Hi guys,
I've had a read of quite a bit of the catch can setups, however it has honestly left me a bit confused so I just wanted to clarify before I went ahead.
Can you please let me know if the following set up for the catch can is effective from the pics below?
Notes:
Original - 1:
this is how it is currently without the catch can in place.
The green dot means it is blocked off there. The intake manifold has instead been linked to the ViPec ecu.
The green loop means it is connected between rocker covers
The green snake to the right is exhaust side connected to the intake
Original - 2:
this is what the planned hosing will look like. Modified hoses are in blue, green means they're the same as before.
The exhaust side has been re-routed to the catch can
The other port on the catch can has then been routed to the intake.
Cheers all
Edited by PSIKO
https://www.sau.com.au/forums/topic/439589-rb26-catch-can-install-confirmation/
why not just run both to the catch can? and plug up the intake? this will stop your oil vapour being recirculated through your intake and making everything dirty and lowering your power....not sure if its legal tegal to do this in WA though.
As above ...your plan looks ok. Do you have some form of baffles in your catch can? If not and you are getting too much oil into your intake you might need an additional oil/air separator and/or put some mines baffles in the cam covers or make your own.
If the legalities of it all weren't a concern, this would work wouldn't it?
Thanks for the replies everyone.
I'm not quite sure, I'll have to contact the people who originally made it and ask them as I can't visually inspect inside it.
So I can keep the other port on the rocker cover intake side blocked off?
And that line from the intake manifold is fine going to the ECU and not connected somehow to the other vacuum lines? Just concerned that I need to connect in the PCV valve to the system, that's all.
Many thanks again!
Many thanks again!
Yep route both cam covers to the catch can and you could block off the pcv valve too. The line going from the intake manifold to your ecu is presumably for the map sensor and should not be connected to any other line.
If it's a Sri catch can there's a hidden breather in the middle on the bottom. Don't know if it provides adequate venting capabilities for a modified engine as the openings very little
Grab a bar, a half inch ratchet extension will do, and gently turn the fittings in the rocker covers to face each other as well. Be careful with how hard you push as the fittings can be damaged if you have to push them too hard. Then you will have one cross over hose between the 2 rocker covers and the 2 outlets facing forward going to the catch can. Makes it look a little less obvious to the boys in blue. They should end up looking like this, bare in mind these rocker covers arent sitting correctly, but i am sure you can see what i am getting at. It just means there is nothing blocked off and it looks neater as well
Where the can sits isn't a problem there's enough space there but if you look up the breather on the bottom, the gap between where the tube ends and the top of the catch can is very small compared to the surface are of most breathers which seem to be about -16
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
