Micolour Sauvic Deca - 22Nd March 2014 - Rnd 1
Proudly Presents:
Micolour SAU-Vic Deca Motorkhana ROUND 1 of the 2014 CHAMPIONSHIP
When : Saturday 22nd March, 2014 (7:30am)
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $120 per entry
Max Entries: 50 + Reserves
Entry Form & Supp. Regs: HERE
Event Schedule:
ENTRY FORM IS REQUIRED TO BE PUT ONTO THE LIST. PAYMENT IS REQUIRED TO STAY ON THE LIST.
***********************IMPORTANT CHANGES:**************************
We will NO LONGER be able to sell AASA licenses on the day. It is your responsibility to make sure that this is completed prior to the event and that you produce and supply the license on the day of the event.
If you forget your license on the day or if you do not have a license, then you will not be permitted to enter the event.
  • Please fill out your entry form clearly and in full.
  • If you are emailing you entry, please name the attached file after your full name and what page it is. eg. 'Reon Staprey Disclaimer'
  • All withdrawals will be refunded after the event. Refunds will not be given after 5pm Sunday the 16th of March.
  • The insurer of the event (AASA) has issued supplementary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
  • This also impacts passengers, as they must wear a helmet prior to entering a competition vehicle.
  • A fire extinguisher is required by all entrants and needs to be bolted to the vehicle. Screws or cable ties are not acceptable.
  • Please re-read the supplementary regulations before entering the event.
  • GATES WILL BE OPEN AT 730AM. Cars need to be scrutineered before drivers briefing at 9am sharp.
  • Grouping requests: If you have anyone that you would like to be grouped with, send me a PM and I will try to accommodate.
Please support our sponsors:
Micolour – Custom Refinishing, 7 Dissik St, Cheltenham 3192, Ph: (03) 9555 8011
  • Like 1
Entry list:
1. Micolour
2. Micolour
3. Leon Stapley 180sx
4. Jake Lowry S14
5. Simon Henman HMAS-33
6. Campbell shobbrook sil80
7. Russell Cunningham sil80
8. Mathew Femino Prob GTR
9. Paul Stephenson 32R
10. Luke schulze 33 GTS-t
11. Daniel Jones s14
12. Sean Power s13
13. Jett Benson 180sx
14. Shane Janssen 33R
15. Neil Gray S13
16. Anthony Femino gts-t
17. Travis Eva S13
18. Greg Calmer S13
19. Juilette Remfrey BR86
20. Shivam Rohit 32R
21. Rhys Yeomans XR5
22. Chris Wilshire XR5
23. Marrrrrrrk Ryan HMAS-33
24. LLoyd Waldron MR2
25. Kurt Thompson S15
26. Daniel Lee 33
27. Matt borci 33GTR
28. Joshua Davey S15
29. Trent Couacand HMAS33
30. Ben Felgate S14
31. Min Chan Lotus
32. Mohammad Sharafi Falcon
33. Ahmad Sharafi 33 GTS-t
34. Micheal Bourke VK
35. Damian Hartin Exige
36. Ben Smith 180sx
37. Adam Crane Chaser
38. Joseph Canals Sil
39. Elliot Kerby 318i
40. Mathew Robins R33
41. Michael Silcock S15
42. Robert Amenta R33
43. Evan Boyact Fiesta
44.
45
46
47
48
49
50
Reserve list:
Additionally, your metal bracket must have a metal retaining clip/band that holds the extinguisher in the bracket. Brackets where the extinguisher simply clips in are not acceptable.
Be sure to bolt your extinguisher to a metal part of the body, not a plastic trim.
As above, AASA Licences can no longer be purchased on the day of the event, you will need to apply for your own licence by filling in the following form and submitting it to AASA.
http://australianautosportalliance.com/wp-content/uploads/2011/09/CLUB-LICENCE-APPLICATION1.pdf
Anyone got an idea if hose clamping the fire extinguisher to your role cage would pass scrutineering?
Couldn't find any info in the cams regs.
As above the fire extinguisher must be bolted in.
Thanks odi...
If you don't have your licence - you don't compete
if you forget your licence and cant prove that you have one - you don't compete
if you thought you could get one on the day because someone told you that you could get one on the day and drive 3 hours up to shep, left at 3 am because you worked on your car til 12am to get it ready and maxed out your credit card just to get there - guess what.... YOU DON'T GET TO COMPETE.
  • Like 2
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
