Micolour Sauvic Deca - 22Nd March 2014 - Rnd 1
achoo
 Share
Coffee machine onsite....im in. also getting my brother to register as well. (im currently sorting out my cams license).
So i'll put my application form in and arrange payment and put TBA and bring my receipt from cams if i dont have my license in time?
I'd recommend putting in a call to Cams after you submit the application to ask them to fasttrack it because you've got an event coming up... if you don't have it by say... Wednesday... give them a call back and ask for a quick cover letter to be emailed to you saying that you do have a licence, with the number, etc...
Ive got my cams number and ive lodged online for my license. so thats all sorted and paid for.
Reading the Entry form and it states - Entry is open to members of affiliated car clubs.
Our Club is cams affiliated so is that ok? or does it mean affiliated with SAU?
Any CAMS affiliated club is fine. Membership must be in date too. Proof is required (membership card)
Cool payment sent this morning. My brothers putting in his now. i'll have a membership card along with (hopefully it turns up by then) my license on the day.
Now to wash the dust off the car and get it ready,
Just wanted to get an update on how many entrants there were right now? The list is a little bit out of date. My mate is keen, but doesn't want to register and prep his car only to find out he's way down the reserve list.
Thanks!
Get him to enter, the front page list a definitely a few cars behind, but if he enters now he'll be on the list for sure. There's still two weeks to go, people always have some car hiccups and need to cancel, so even if he does go into reserves he'll get in (or full refund, so no risk)
Just a reminder NO AASA NO CAMS LICENSE NO ENTRY. You need to have these or a letter from said companies saying that you have one and it's in transit or guess what.......you get a free entry to being a spectator or better still a volunteer :)
try trik trailers in bayswater
hired them about 8 times now
Hopefully they have plenty as I have to call up & book our trailer tomorrow from there!
hey guys so i found a flat bed car trailer 50bux a day. it only has a winch to hold the car which isn't enough. Never towed a car before, how can i strap down the car? I've seen tow trucks strap wheels down but this thing dosnt have a spot for it.
trailer looks like this:
http://www.gumtree.com.au/s-ad/dandenong/trailers/tandem-car-trailer-car-carrier-hire-just-50-per-day-/1041572051
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
