Micolour Sauvic Deca - 22Nd March 2014 - Rnd 1
achoo
 Share
get some decent heavy duty ratchet straps, ideally the 3" wide ones
at least 1 strap around the rear sub frame and 2x up the front (either lower control arms, through the wheels, tow points etc etc)
also position the car slightly forward, but not to much, of the centre balance point of the trailer, so you have some down force on the ball
hey guys so i found a flat bed car trailer 50bux a day. it only has a winch to hold the car which isn't enough. Never towed a car before, how can i strap down the car? I've seen tow trucks strap wheels down but this thing dosnt have a spot for it.
trailer looks like this:
http://www.gumtree.com.au/s-ad/dandenong/trailers/tandem-car-trailer-car-carrier-hire-just-50-per-day-/1041572051
just follow that, sort of.
biggest challenge is usually trying to extend ramp length if not prepared.
Entry list:
1. Micolour
2. Micolour
3. Leon Stapley 180sx
4. Jake Lowry S14
5. Simon Henman HMAS-33
6. Campbell shobbrook sil80
7. Russell Cunningham sil80
8. Mathew Femino Prob GTR
9. Paul Stephenson 32R
10. Luke schulze 33 GTS-t
11. Daniel Jones s14
12. Sean Power s13
13. Jett Benson 180sx
14. Shane Janssen 33R
15. Neil Gray S13
16. Anthony Femino gts-t
17. Travis Eva S13
18. Greg Calmer S13
19. Juilette Remfrey BR86
20. Shivam Rohit 32R
21. Rhys Yeomans XR5
22. Chris Wilshire XR5
23. Marrrrrrrk Ryan HMAS-33
24. LLoyd Waldron MR2
25. Kurt Thompson S15
26. Daniel Lee 33
27. Matt borci 33GTR
28. Joshua Davey S15
29. Trent Couacand HMAS33
30. Ben Felgate S14
31. Min Chan Lotus
32. Mohammad Sharafi Falcon
33. Ahmad Sharafi 33 GTS-t
34. Micheal Bourke VK
35. Damian Hartin Exige
36. Ben Smith 180sx
37. Adam Crane Chaser
38. Huy Tran Stag
39. Elliot Kerby 318i
40. Mathew Robins R33
41. Michael Silcock S15
42. Robert Amenta R33
43. Evan Boyact Fiesta
44. Joseph Canals S13
45
46
47
48
49
50
Reserve list:
If your name is on this list and you are bringing friends. I need them to help out with running the day.
If you could please visit the officials page and show some interest.
This will be the last time i say PLEASE.
Cheers WayneO
Shoot off an email to [email protected] with your details.
However:
"• Entry fee is as stated on the entry form (AUD $120). Entries open and close at the times/dates as stated on the
entry form. NO refunds will be issued after 5.00pm on Monday 17th March 2014."
i want to drive my car down with a pert but if i get pulled over not sure way to say, does anyone know any workshops in shep?
Use my work as an excuse bro. Ken Muston Automotive. At least you've got some that can vouch for you if the cops actually ring up! I'm working Saturday so I'll be there.
 Share
    • There are a few variables here, some are relevant but not critical (IMHO) to help answer your question. The two major things: 1) Ignoring anything to do with forced induction - all engines have their own natural torque curve, and it will ALWAYS roll over higher in the rpm.  There is a fixed relationship between power and torque.  When dealing with kw and nm, the relationship between them is roughly: kw = (rpm * nm) / 9549 nm = (kw / rpm) * 9549 The peak torque of an engine (without boost) will typically climb until somewhere nearish the middle of it's operating rev range, give or take a bit - then start dropping again.   The nearer the minimum and maximum rpm of the engine the steeper that drop off tends to be. 2) Boost simply increases the density of the air going into the engine, which inflates the torque at that point.  The ramp up in the torque curve you see on a turbo engine is due to the boost rising, but it's essentially just multiplying the torque you'd see if it was naturally aspirated.  The roll over you see at the end will typically be what would have always happened with the engine, whether it was naturally aspirated or turbocharged.   If the torque never started dropping then power would climb infinitely. The cool thing about this is you absolutely can tune the power delivery to suit the needs of the owner and/or the limitations of the car, and I regularly do this.    With modern turbos we've got to the point where a setup that someone may run well over 20psi of boost with could actually reach target boost well under 4000rpm if the tuner/owner WANTED to - and a lot of people seem to do this when there is actually no realistic benefit, generally it just adds a massive amount of strain to the engine and drivetrain and often actually makes the car harder to drive. As a general rule I tend to tune the boost curves for cars I tune to reach a "useful" torque level through the rev range and will often end up with a curve that ramps hard to a point, then creeps for the rest of the rev range - not to make the boost curve "soft" as such, but more to make sure its neither laggy nor pointlessly violent in it's delivery.   There have been cars I've tuned to be almost like a centrifugal supercharger (or naturally-aspirated-ish) where they actually only hit like 8psi of boost before opening the gate, then ramp up the next 10psi over the rev range... if the car is "loose enough" to drive. On the flip side I've tuned a car that had stock cams and the engine's natural torque curve fell over HARD in the higher rpm and resulted in a slightly awkward power curve to work with, in that case I actually started ramping up boost to boost torque in a way to offset the engines "NA" torque drop off... at peak rpm actually running a good 5psi+ more boost that what the "flat curve" would have defined.  This gave the owner an extra 500rpm or so of useable rev range, and had a fairly solid impact on times he was running at motorsport events due to being able to hold gears a bit longer and also falling into a more useful part of the rev range in the following gears. Here's an example of an RB in a GTSt I've done the "softened" boost curve to not pointlessly ramp straight to the max boost target early in the rpm, but still made sure it builds useful boost.  If you went in the car you'd not guess at all that the boost curve was doing anything "weird", it feels like it spools immediately and accelerates relentlessly (traction dependent) and holds to max rpm.   I don't know if you'd guess what the boost curve was doing by driving the car, or even looking at the dyno plot... but imho it suits the combination.
    • therefore on the first examples, as we see, changing cams (graph 2) influences the quantity of torque at high revs its OK for me. so a tuner can act on the wastegate via the boost controller to increase the boost at high revs? on the last example, the boost does not decrease ok, but the torque does. this can come from cams etc etc ok. but on the other curves the boost is not constant, it increases, this is what I find strange to my mind. even more so if it comes from the relief valve. sorry I'm very new don't blame me. in my mind I couldn't imagine how the boost could be higher after the spool
    • right, but fundamentally, for a given mechanical setup, you are either using all the torque (and therefore power) it will give, or you are choosing to run it less efficiently. Many tuners will have a practice of identifying peak available torque and then winding it back a couple of % for safety, but unless you are working around a very specific issue like a weak gearbox, there is nothing to be gained by making 20 or 30% less than the engine can
    • You can manipulate the torque delivery by ramping in boost gently, then throwing it all in after peak torque to keep the torque flat. It's nothing magical.
    • Tuning the wastegate to do it. That is all. Most people want the boost to not fall off like the most recent example. Those also look like dyno runs with an Auto/Torque converter setup, which does fun things to the graph. The boost tapers down like that because the turbo cannot supply the same amount of air at 7000rpm that it can at 3000 in terms of PSI. That, or the tuner has decided that it tapering off like that is what someone chose to do. IF you have a wastegate that can't bleed enough air to slow the turbine, and IF that turbo can flow enough air to feed the engine at high RPM, you get 'boost creep' which is a rise of boost pressure beyond what you are capable of controlling and/or want. None of these show symptoms of that, but if you had a run that was 20psi at 3000rpm, and 27psi at 7000rpm, it could be an example of that. Or simply that the person wanted boost later for their own reasons... The dyno graphs don't always show the full context.
