Micolour Sauvic Deca - 22Nd March 2014 - Rnd 1
achoo
 Share
get some decent heavy duty ratchet straps, ideally the 3" wide ones
at least 1 strap around the rear sub frame and 2x up the front (either lower control arms, through the wheels, tow points etc etc)
also position the car slightly forward, but not to much, of the centre balance point of the trailer, so you have some down force on the ball
hey guys so i found a flat bed car trailer 50bux a day. it only has a winch to hold the car which isn't enough. Never towed a car before, how can i strap down the car? I've seen tow trucks strap wheels down but this thing dosnt have a spot for it.
trailer looks like this:
http://www.gumtree.com.au/s-ad/dandenong/trailers/tandem-car-trailer-car-carrier-hire-just-50-per-day-/1041572051
just follow that, sort of.
biggest challenge is usually trying to extend ramp length if not prepared.
Entry list:
1. Micolour
2. Micolour
3. Leon Stapley 180sx
4. Jake Lowry S14
5. Simon Henman HMAS-33
6. Campbell shobbrook sil80
7. Russell Cunningham sil80
8. Mathew Femino Prob GTR
9. Paul Stephenson 32R
10. Luke schulze 33 GTS-t
11. Daniel Jones s14
12. Sean Power s13
13. Jett Benson 180sx
14. Shane Janssen 33R
15. Neil Gray S13
16. Anthony Femino gts-t
17. Travis Eva S13
18. Greg Calmer S13
19. Juilette Remfrey BR86
20. Shivam Rohit 32R
21. Rhys Yeomans XR5
22. Chris Wilshire XR5
23. Marrrrrrrk Ryan HMAS-33
24. LLoyd Waldron MR2
25. Kurt Thompson S15
26. Daniel Lee 33
27. Matt borci 33GTR
28. Joshua Davey S15
29. Trent Couacand HMAS33
30. Ben Felgate S14
31. Min Chan Lotus
32. Mohammad Sharafi Falcon
33. Ahmad Sharafi 33 GTS-t
34. Micheal Bourke VK
35. Damian Hartin Exige
36. Ben Smith 180sx
37. Adam Crane Chaser
38. Huy Tran Stag
39. Elliot Kerby 318i
40. Mathew Robins R33
41. Michael Silcock S15
42. Robert Amenta R33
43. Evan Boyact Fiesta
44. Joseph Canals S13
45
46
47
48
49
50
Reserve list:
If your name is on this list and you are bringing friends. I need them to help out with running the day.
If you could please visit the officials page and show some interest.
This will be the last time i say PLEASE.
Cheers WayneO
Shoot off an email to [email protected] with your details.
However:
"• Entry fee is as stated on the entry form (AUD $120). Entries open and close at the times/dates as stated on the
entry form. NO refunds will be issued after 5.00pm on Monday 17th March 2014."
i want to drive my car down with a pert but if i get pulled over not sure way to say, does anyone know any workshops in shep?
Use my work as an excuse bro. Ken Muston Automotive. At least you've got some that can vouch for you if the cops actually ring up! I'm working Saturday so I'll be there.
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
