Hi All
On the weekend I parked on the side of the road on uneven dirt/gravel with the nose downhill. When I attempted to reverse back onto the road the two wheels on opposite corners (under least resistance) of the car just started spinning and the car didn't move. Had no space to go forward so I hit the syncro switch but nothing changed. Tried a few combos etc but the same wheels just kept spinning. Ended up having to ask some kind bystanders to push me out.
Does this sound normal? does synchro mode only work in forward? Is there something I'm missing? How does one even check if it works?
Thanks
Tim
https://www.sau.com.au/forums/topic/439613-stagea-stuck-on-dirt-s2-wgnc34/
Synchro mode is working LSD is not. You need a proper mechanical LSD. You can tell if the synchro mode is working because both (in your case only on one side) front and rear are spinning.
I was under the impression that the synchro mode locked the front diff???? I know that this does happen on mine, when engaged it becomes hard to turn on dirt (drives through the turn) although I have never tried it in reverse.
Nope synchro mode just distributes drive 50% front and rear (at low speeds) . Front has no LSD although a good mod if you have already done the back!
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
