Nah just the $65 to enter but that fee also used to cover one passenger for "pit crew". Not any more though. Now they have to pay their own entry on top.
Oh I see. Small price to pay anyway. Im used to throwing away nearly a k for a drift event. I'll even have cash left over for after calder kebabs!
  • Like 1
Calder is still the same old... Lucky if you get 3 runs on a Friday night etc.
If I were all of you, I'd be finding out if you can attend the below event... WRX Club have a drag night on the 8th, Sat night:
http://www.wrx.com.au/Default.aspx?pageId=1540753&eventId=853226&EventViewMode=EventDetails
They have hired the circuit for the Sat Day time so likely have just rented out the place for the evening also.
You'll likely get closer to double the amount of runs, if not more, given Calder pack as many cars as they can into a Fri night to pocket as much cash as possible. Probably less track time loss as well with shitboxes etc.
  • Like 1
heya mate should have come and said hello! was yours the white gtt?
best et i got was 12.4 and mph was 120. Had no traction off the line unfortunately.. Time to buy stock rear suspension and et streets
yeh mate :). I had the same problem.. running stock rims on the rear with shit 225 tyres, no traction :/ could only manage a 14.1.. packed it in after 5 runs. need to invest in some radials. 275rwkw for a 14.1 was embarrassing lol
60' was 2.5s
14.1 @ 110mph
60' was 2.5s
14.1 @ 110mph
Did you lift off before the end?
110mph is about 220rwkw, not 280, fairly big gap there!
Didn't lift off just found it hard to find traction.. first time running the car thought stock rims with new tyres would suffice but soon found out wheel spin everywhere, didn't get one decent launch and was only launching at 3-4k rpm.. Best run was no launch at all. Stock rims are too narrow and even though the tyres are new they are some shit Chinese tyres
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
    • So I'm confident in saying its TCS thing. My new cluster I never realized didn't even have bulbs in the TCS or Slip slots. Shining a light through the backside that black plate has nothing for it, unlike my original cluster. Looking at the service manual the only thing that stands out is TCS in relation to the vehicle speed, it has nothing to do with turbos. It sadly looks like I may just need to get the appropriate cluster.
